Old 04-18-2016, 08:16 AM
77 Canamman's Avatar
Talking 77 Trans Am updates
I have gotten much done on my newly purchased '77. Here are some shots. More to come!
ID:	426527   Click image for larger version
ID:	426528   Click image for larger version
ID:	426529   Click image for larger version
ID:	426530   Click image for larger version
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-18-2016, 08:17 AM
Thumbs up
Old 04-20-2016, 01:04 PM
Poncho Dave Poncho Dave is offline
Maybe in a couple years mine may look that good!
Old 04-20-2016, 01:11 PM
Thank you. I have a NOS Delco master cylinder and brake booster to replace the incorrect parts on there right now. I also need to install the heat stove for the air cleaner.
Old 04-20-2016, 07:47 PM
W72-Bandit's Avatar
W72-Bandit W72-Bandit is offline
That is a sharp T/A!
'79 SE T/A 400/4spd
'12 ZL1 Camaro
Old 04-21-2016, 01:03 PM
SD455DJ SD455DJ is offline
77 Canamman, Nice TA! Remove the headers and your ready to race at the Pure Stocks if the motor is stock(-ish)! Do you have more pics of the car?
Dennis
Old 04-21-2016, 01:30 PM
Pretty sharp!
Old 04-21-2016, 07:38 PM
Thumbs up
ID:	426774   Click image for larger version
Old 04-30-2016, 10:31 PM
Wink
Ames sourced reman tilt column:
Heat stove and tube installed:
Also, I figured out the reverse lights. I used a switch setup from a '63 Vette, since they used a BW T-10 trans. I made a harness that plugged into the connector on top of the steering column, and ran it through the firewall down to the connector on the transmission mounted switch.
With the 4 tube headers, using the original backdrive linkage was not an option.
Here is a later 60's Vette with a Muncie, but this is extremely similar to the setup that is on my BW ST-10:
ID:	427460   Click image for larger version
Old 05-01-2016, 09:28 AM
The Boss's Avatar
The Boss The Boss is offline
NICE!
And go racin' in the street.
Old 05-01-2016, 04:55 PM
77 TRASHCAN's Avatar
Is engine stock?
Is that one of those battery covers w/ caps?
Look'n Good!
Shut it off
Shut it off
Old 05-01-2016, 07:09 PM
The W72 is stock other than the headers and rejet/recurve. The topper is one I made from an original R89WP battery I found in a parts car I purchased
Old 05-01-2016, 11:15 PM
Very nice rick. Car is great looking.
Old 05-02-2016, 09:46 AM
Just wondering. THe engine paint looks nice!
Shut it off
Shut it off
Old 05-02-2016, 10:29 AM
Bentwheelbob's Avatar
The whole car looks fantastic - congratulations. Like the new master cylinder & heat shield. Really coming together. You may have already checked, but I believe the 1977 vacuum line diagram shows the correct color vacuum lines. Not sure how what level of accuracy you are after, but it looks pretty OCD to me which is my style as well.
Good luck and have fun.
Old 05-02-2016, 10:37 AM
That paint is from Bill Hirsch. The color is really close, but it is too glossy as compared to the original lacquer based engine paint.Still looks far better than a rusty mess!
Old 05-02-2016, 10:43 AM
Wink
I want the overall appearance to be as close as possible to factory. I will look further into the vacuum lines. I know the yellow striped on the air cleaner is correct. I referenced John Witzke's '77 and another very low mile '77 for my inspiration.
ID:	427565   Click image for larger version
ID:	427566   Click image for larger version
Old 05-02-2016, 11:49 AM
Seems like the paint on mine was a tad lighter. In fact it seemed real close to the non metallic light blue used in the early 60's.
Being original is cool, not sure why vacuum hoses have to be perfect...to each their own...
Shut it off
Shut it off
Old 05-02-2016, 08:35 PM
Cool
Here is the vacuum hose diagram for a 1977 Manual Trans W72:
I replaced the incorrect worm gear clamps with the Wittek tower type, and positioned them like Mr. Witzke's car:
ID:	427606   Click image for larger version
Old 05-02-2016, 09:12 PM
They don't, and you are right, that's what makes America great. I like them that way and so does 77Canamman it appears. I appreciate that in him, but don't begrudge you if you feel differently. The beauty of this forum is finding people you have things in common with, and not being an ass to those you don't.
Nice work 77Canamman. What's a shorter name?
