Look for an industrial brake shop. One that does brake & clutch rebuilding for heavy truck/construction equipment. They can handle it correctly. Here in the Phoenix area the only place I would trust for that type of work is Arizona Brake & Clutch.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
Not sure of you have found hubs yet. the 65-70 front cast iron drum can be removed from the hub by simply pounding out the wheel studs. I have replaced many grooved or cracked used drums onto original hubs. you will need a new set of front wheel studs when you replace the drums. I have a couple sets of hubs if you are still looking for a set. email me at [email protected]
1965 2+2 1966 Catalina Convert 1968 Firebird 350 1969 GTO 1967 Bonneville 4 Dr Brougham 428 1967 Bonneville 2 dr 1959 Buick LeSabre 2dr |
