Old 05-17-2016, 08:42 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Question aftermarket radiator
Posted this in heating and cooling but no answers as yet,
http://www.ebay.com.au/itm/301544147...%3AMEBIDX%3AIT
So, thinking about going to a alloy radiator with twin fans and shroud, like the one in the link.
My question is once I remove the factory fan shroud, how does the after market radiator sit at the bottom as the factory shroud holds the Radiator Support Cushion Insulators.
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
Old 05-18-2016, 10:32 PM
MD79TA MD79TA is offline
Default No help but interested
Great price would love to hear from any who have expierence with them.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 05-19-2016, 07:06 AM
Gtozy's Avatar
Gtozy Gtozy is offline
Do u mean top or bottom? ....ive got that same Champion radiator and fan set up. not fully fitted as yet. i am not as concerned with the lower mount as mine are secured into the lower section of the rad support. Its the top where the shroud supports the cushions that i have concerns as i will not be using the factory shroud..
I am fabbing up a bracket atm to support the top, will be chromed ultimately.
Dave
Dave.
Check my build thread here
http://forums.maxperformanceinc.com/...d.php?t=753467
Old 05-19-2016, 07:19 PM
Ozzmann's Avatar
Hi Dave, yea, I do actually wonder about top and bottom. My factory shroud holds both in position, how did you mount to the bottom of the rad support?
Would you have a pic handy. I'm not sure which way to go yet, if to hard I'll stick with the factory setup.
Old 05-19-2016, 10:56 PM
Gtozy's Avatar
Ok, so here we go. Hope it helps.
1st pic shows lower insulator on the Rad Support
AS you can see i have a reproduction Rad Support, I was going to remove the extra trailing edge it has, but it will be handy for mounting the Radiator
Its not finished yet, but this will be the bracket that secures the top
Dave.
Old 05-19-2016, 11:45 PM
Ozzmann's Avatar
Awesome, thanks Dave, I wonder if that bottom mount is a 68 thing, anybody know?
What's the Champion rad build like Dave?
Old 05-20-2016, 12:32 AM
Gtozy's Avatar
My car came like this, i just assumed they all were. 1968 service manual shows it the same way.
The Champion Rad looks great, fully welded, polished up nicely, shoud and fans seem good too.
Dave.
