Old 05-21-2016, 06:42 AM
Judge273's Avatar
Judge273 Judge273 is offline
I understand it wasn't a big deal to replace rear gears with a posi unit?
Factory gears were not what most buyers wanted was what I heard?.
My 71 GT-37 4M-22 455 HO wasn't a posi, but it had it with 3:73 gears?
Mike/Illinois
  #482
Old 05-21-2016, 11:08 AM
Jack Peters's Avatar
3:73 would be dealer installed. 3:55's were the lowest from the factory w/455HO regardless of which A body it was ordered or came standard in.
JLP
  #483
Old 05-21-2016, 11:19 AM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Factory gears are what most people wanted. It was rare to have a customer special order a car with specific axle ratio. Optional gear ratios were rare by 1971, usually for trailering or towing purposes. Factory GM rear ends are quiet (and warrantied), so unless it was the extremely rare case of a car being special ordered for drag racing, factory gears were selected.
Items that customers may go cheap on were wheels and/or radio because they may want to install aftermarket units.
One nice thing about 1969-1980 Trans Ams, they ALL had posi. Even those 185 hp, 2.41 or 2.56 geared cars from the mid-1970's, or the base 1979-1980 Trans Am with a 301 non-turbo, came with posi. The main reason Trans Ams were always a junkyard hunter's favorite because if they found a TA intact, it had a posi rear end which fit Camaros, Novas, etc.
Mike
  #484
Old 05-21-2016, 12:40 PM
Judge273's Avatar
Thanks Jack and Mike,
The 3:73 gears were Pontiac gears and posi. Maybe they wanted those and couldn't get factory. Not sure that car was for cruising or such. Heard it was a rum runner or something like that.
Mike/Illinois
  #485
Old 05-21-2016, 04:55 PM
A huge percentage of original buyers of the more street driven '71-72 455HO cars stuck with the gear ratio that their cars were delivered with. I seldom run across different ratio gears having been setup up in these, esp, in cars that were driven quite a bit.
On some of the '71 and '72 HO cars, esp, the lightweight '71 233's, quite a few were raced in stock or modified production class with tall slicks, auto cars with 3500-400 stall converters. Gears typically 4.10's or 4.33's. I set up a set of thin Richmond 3.73's in the Monk King T-37 nearly 20 years ago. In previous modified production racing in the '70's, it had ran 4.10's in combination with SR '70 RA4 heads, believe a General kinetics cam. The white/ jade green bench interior '72 GTO originally owned by Truman Fiels also is a really low mile mainly raced and nearly as light as it gets ffor a '72 HO A body. it's another one that had 4.10's and 4.33's installed over the course of its career.
On the 455 and 455HO Convertibles, ESP, T400 cars, not getting a posi, that was very common. money was spent elsewhere. I've set up now nearly a half dozen Eaton posis in '70 455 GTO auto converts. All but one of them had factory 3.07 peglegs in them. There seems to be some belief amongst long time muscle car guys that the 201 '65 Z16 Chevelles got along fine without an Eaton posi being factory installed. Have heard that over and over with the reason being the Z16's use of the HD boxed frame negated a lot of the need for the posi. not sure about that one, though it probably held true for those that were not going to be at the strip nearly every weekend with their new Z16 Chevelle.
  #486
Old 05-21-2016, 05:54 PM
flyingn's Avatar
flyingn flyingn is offline
being into Ford too and seeing many marti reports Id venture a guess that more performance Fords(Torinos, Mustangs, etc) were not factory locking rear equipped. Wild guess Id say 65-70% of the ones left the factory with open rears
Frank Szymkowski
1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, Safe T track, 3.55's, ps and radio.
1971 Torino 351c 4v GT convertible. White on white with black interior
4 speed, shaker, am/fm, ps/pdb, buckets/console, ac.
One of 26 made
  #487
Old 05-21-2016, 07:55 PM
MikeNoun's Avatar
I've always wondered about the claim that there was no traction issues with the open rear end in 1965 Z16 Chevelles. Original road tests state that both tires spun, and traction was great, all due to a stabilizer bar mounted between the lower control arms.
If this stabilizer bar worked so well, I wonder why Chevy eventually went to posi?
1965 Chevelle Z16's only ran in the mid-high 14's, yet the publications that heralded this "wonderful advancement in traction" stated that the car was handicapped by not having a Limited Slip Differential. Go figure...
1965 GTO tri-power with 3.90 gears, 4-speed, and Safe-T-Track would still whip its butt.
  #488
Old 05-23-2016, 03:18 PM
judger69's Avatar
judger69 judger69 is offline
'71 judge 'vert no sale on Sat. at $220,000 ?
https://www.mecum.com/lot-detail/SC0...ble/Automatic/
  #489
Old 05-23-2016, 04:56 PM
Judge273's Avatar
This one was a bit of a shocker....it was offered on PY awhile back too by original owner.
https://www.mecum.com/lot-detail/SC0...-IV/Automatic/
No sale at 110k?
Mike/Illinois
  #490
Old 05-23-2016, 07:15 PM
flyingn's Avatar
heres a beauty
  #491
Old 05-23-2016, 07:16 PM
flyingn's Avatar
and another..
Frank Szymkowski
One of 26 made
  #492
Old 05-23-2016, 08:51 PM
judger69's Avatar
No sale at 110k?
I'm no expert but it is has a LOT going for it. Still has its original ram4 engine with 51,000 on the clock, 1 of 72 ram4 autos made in 1970, single family car so the history is known. Original Ram4 has never been rebuilt. Seems pretty rare.
Not many 4's have the original engine let alone never been rebuilt.
Wow, beautiful car. To be honest, I thought it should go higher.
  #493
Old 05-23-2016, 09:24 PM
starlightblack's Avatar
starlightblack starlightblack is offline
I would bet a bunch of dough that Chevrolet strong-armed that claim out of the magazines, "or we will pull our ad buy". Wouldn't be the first time a manufacturer wanted copy to read a certain way..."or else"
  #494
Old 05-23-2016, 09:43 PM
MikeNoun's Avatar
But what doesn't make sense is why Chevrolet chose the open rear end with a stabilizer bar between the control arms setup instead of just offering posi? Seems like a lot of extra engineering involved here, and they made sure magazines wrote glowing reviews of how they "solved the traction issues" on Z16 Chevelles, but they obviously didn't.
One theory I had was that they didn't want people drag racing the first 201 they built, possibly to prevent breakage and poor publicity, so they simply stuck them with peg-leggers.
Another theory is that the test cars had the stabilizer bar within the control arm setup, and they actually DID have posi, but did not tell the magazine testers about it.
I can't see how a non-posi rear end could lay down two perfect black marks.
At least that's what "My Cousin Vinny" taught me.
Mike
  #495
Old 05-23-2016, 11:00 PM
Am sorry I derailed the Judge pic topic.
On the boxed frame no posi Z16 Chevelle deal, those cars were really expensive for the time, and the well healed buyer that bought one, surely could have afforded an extra $40 on the invoice for PosiTraction, so not sure how accurate my early comment was about keeping the price down. One would think quite a few dealers would try and order an Eaton posi in their Z16's. With the boxed frame, partial boxed lower sway bars, and the 7/8" rear bar, there had to be less frame twisting than with a std frame and open rear arms & no rear swaybar.. Not sure how many on here have ever examined the factory boxed lower control arms on a Z16, but they were basically robbed from the early 442 parts bin, and the sides of the lower arms eventually cracked where the partial bracing stopped. They are not like the later boxed lower control arms.
On the 389 and 400 GTO converts, plenty of them were ordered with Safe-T-Track. It just seems odd that so many '70 and '71 455 equipped GTO converts, ESP automatic cars, were not ordered with the Eaton posi carrier. Near 500 ft lbs of torque at a lower rpm, and no posi...Hmmm.
  #496
Old 05-24-2016, 07:38 AM
Judge273's Avatar
I know ....Really!
Mike/Illinois
  #497
Old 05-24-2016, 07:56 AM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
Lightbulb
No sale at 110k?
Beautiful car, but you can bet it's the auto trans that hurts it.
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
  #498
Old 05-25-2016, 12:32 PM
SD455DJ SD455DJ is offline
I know ....Really!
Sure mislocated the RAM AIR hood decals, otherwise it's really nice (Aztec Gold?).
Dennis
  #499
Old 05-25-2016, 04:09 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Question
Dennis
Agreed, Dennis. Whomever applied those RAM AIR hood callouts was on some SERIOUS pharmaceuticals!
Thinking that color might be Castillian Bronze?
Regards,
"455HO" Lloyd
  #500
Old 05-25-2016, 04:16 PM
Lloyd, That color is niether, but it must be from the bad lighting, but it still looks closer to Dan's baby-poop Aztec Gold GTO. Castilian Bronze is a reb-brown, or rootbeer, right?
Dennis
