Old 06-17-2016, 06:43 PM
gman005's Avatar
gman005 gman005 is offline
Default Front end limiter installation
Does anybody have a picture of how they have there limiters installed on a abody?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 06-17-2016, 08:15 PM
Gary Kubisch Gary Kubisch is offline
Google image search ....
Old 06-17-2016, 08:33 PM
Gman 6900's Avatar
Gman 6900 Gman 6900 is offline
Default limiter
This is how mine is.
68 Lemans 505 cu in
[email protected]
69 FB 455 cu in
11.97
Old 06-17-2016, 09:17 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Do u have stock A Arms?
[email protected]. 3460#s
Old 06-18-2016, 07:45 AM
johnta1 johnta1 is online now
What kind of rear suspension setup?
Old 06-18-2016, 09:37 AM
gman005's Avatar
Stock front control arms. The rears are edelbrock uppers and lowers with strange double adjustable shocks.
71 Lemans Sport.
Old 06-18-2016, 10:08 AM
LiL Jack's Avatar
He is having a problem with wheelies, not knocking the tires off the car.
Old 06-18-2016, 10:14 AM
LiL Jack's Avatar
Do what a few guys did in the picks above for limiters. Try 3"-2.5" of front end travel. That should calm those wheelies down.
I just measure from the center of the center cap on the rim to the bottom of the fender when u jack the car up in the front crossmember. Just measure the turns u put on the limiters and make it the same for both sides and that will get you in the ballpark.
Old 06-18-2016, 11:08 AM
60man's Avatar
60man 60man is offline
Ditto. My wheelies are no where that extreme but I can tell when I limit the travel/tie down. I also put on single adjustable shocks up front. In retro I should have done double adj. ? Prolly pull bars off now and loose some weight. Lol
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 06-18-2016, 12:46 PM
gman005's Avatar
Front shocks are Viking double adjustable.
71 Lemans Sport.
Old 06-18-2016, 01:58 PM
60man's Avatar
Go max on extension doesn't help! ?
ECM member.
MANDRA
Old 06-18-2016, 03:59 PM
Well, after he gets done phucking around with the shocks, then maybe he will need the correct answer?
Old 06-18-2016, 05:48 PM
LiL Jack's Avatar
The problem is on the front of the car NOT the back of it. The shocks he has are probably fine, he needs to limit the front end travel to keep the front of the car from coming up. From the video the shocks look loose also.
He has a car that makes power not a slow azz dragster that wouldn't pull the from tires if you sprayed it.
Old 06-18-2016, 06:15 PM
And where is the power to the ground coming from?
My slow dragster pulls the wheels, how does the shock thing work for that?
Tell him how much travel he has with the wheels in the air, whether 10" or 3 feet off the ground?
When you learn to scale your chassis maybe you can tell him how to do his?
Old 06-18-2016, 07:16 PM
slowbird's Avatar
slowbird slowbird is offline
Im sorry but you don't have a clue
Old 06-18-2016, 07:44 PM
LiL Jack's Avatar
Correct!
It's piontless to argue with him.
Old 06-18-2016, 10:18 PM
gman005's Avatar
The shock that was one the car in the video were calvert 90/10
71 Lemans Sport.
Old 06-18-2016, 10:34 PM
1/2-13 stainless nut TIG welded to the A-arm, 1/2-13 stainless bolt with a large flat washer welded to the head of the bolt so the rubber bumper has something flat to bump against. I cut a screwdriver slot in the end of the bolt so you can make adjustments from the top, another 1/2-13 nut locks the adjustment.
Old 06-18-2016, 10:40 PM
mike leech's Avatar
mike leech mike leech is offline
Even considering how stupid you are. That was a retarded post. Crawl in a hole and stay there tard.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 06-18-2016, 10:42 PM
mike leech's Avatar
Right here is what you need.
EHTTFMF!
