Old 06-25-2016, 10:23 AM
wheneaglesfly wheneaglesfly is offline
A friend told me about the The New Generation of Tremecs.
He is a Mopar guy & plans to buy it for his 1970 Charger SE 383.
Stroker 496 BB being built.
New Gen Tremec supposedly Good for 800 ft/lbs & 1,000 HP.
Not sure if that is true or not.
Old 06-25-2016, 10:32 AM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
I assume that when I'm ready, something like that will be the way to go
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 06-25-2016, 10:36 AM
They say the New Gen Of Tremecs are a dream to shift & drive on the road.
Like a High $$$$$$ Super car from Italy.
Old 06-25-2016, 11:24 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
I can only speak for a firbird but it wasn't a bad install. Not really any worse than changing a clutch disc really. Pull old tranny, install new. Didn't have to cut any body but I did have to relocate the provided crossmember which resulted in drilling and nutserting (sp?) the frame at a proper location.
I did it on my back on jack stands. Now keep in mind that if you convrrt to hydraulic setup fabrication and fitting time triples in time, work and complication BUT I'm a 50 yr old guy with no formal auto training and I did it so....
Steve
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 06-25-2016, 11:35 AM
Stan Weiss's Avatar
My brother's '65 GTO came from Pontiac with a 4 speed and 3:90:1 rear. The rpm's never bothered us, but of course in '65 gas was also much cheaper.
There is a ST10 trans with
3.29:1 1st
1.72:1 2nd
1:1 3rd
0.8:1 4th
Stan
Pontiac Pump Gas List
