Old 07-06-2016, 12:32 PM
RonBurgundy's Avatar
RonBurgundy RonBurgundy is offline
Default 454 in a B Body?
Kicking around the idea of swapping in a 454 instead of rebuilding the 389 in my 65 Catalina. I've seen the swap done before but know very little of what it takes to make it fit. Engine mounts, cross member, driveshaft? Has anyone made this swap before in a large Poncho?
Old 07-06-2016, 03:41 PM
Txbobcat Txbobcat is offline
A 455 would be a lot easier swap. And it wont devalue the car like a cheby would.
Old 07-07-2016, 06:07 PM
77 TRASHCAN's Avatar
Although I have NOT performed this swap...
My thoughts would be of using the later 70's type mounts. I talking about the clam shell mounts that bolt to the frame. Chevrolets used them also. The Chevrolets used what looked like a box, open on one end, it had holes front and rear and sat down over the clam shell mount with the typical 6" or so, long bolt joining them together.
You could lower the engine and trans together into engine bay with both parts of the mounts bolted to the engine. Level the engine from side to side.
Not sure at all how this might or might NOT work. Some measuring of frame and mount spacing beforehand would give you an idea if you are close.
Spacers might need to be made if frame is too wide, can't imagine frame being too narrow on one of these car's, another thing to measure before you got too far along.
I'm sure you could use small block brackets on this deal, they are plentiful, came on tons of vehicles. Cars and pickups might be different, if so getting a set of each might give you some adjustability for installation. Buy the frame clamshell mounts new, they are cheap.
Do you already have the 454? If so, what year?
I too favor a Pontiac engine, it's your car. Swapping a 389 for a 454 would weigh fairly close to the same.
Have fun!
Shut it off
Shut it off
Old 07-07-2016, 10:35 PM
I don't have a engine right now just looking to see what's out there. Hoping to find something that's almost ready to drop in. Another idea that came to mind...500ci Caddy!!!
Old 07-07-2016, 10:43 PM
It's not that hard or expensive to find a good-running Pontiac 455 for a reasonable price that's a simple bolt-in deal.
You'll find that you won't get off cheap with all the messing around, fabricating and cobbling that a non-Pontiac engine install will take.
In the end it's going to cost more to put in any Chevy, Olds, Cad or any other non-Pontiac engine.
Old 01-25-2024, 01:21 PM
Zooguy Zooguy is offline
Any updates on the motor swap?
Old 01-25-2024, 02:43 PM
Mr Twister's Avatar
Old post, but a Canadian Export car of the same vintage may have a clue on what parts are needed.
The Following User Says Thank You to Mr Twister For This Useful Post:
Old 03-01-2026, 10:00 PM
kpbrown31 kpbrown31 is offline
Curious if you ended up doing the swap?
