Old 12-02-2013, 11:54 PM
REFORMULATED's Avatar
REFORMULATED REFORMULATED is offline
Originally Posted by hdinch View Post
What is holding down the metal screens inside the scoops?
They screw into two reinforced tabs or bosses on the underside of the hood behind the slits the screens slide into. The bosses are thicker and made to accept the screws. This post shows them and what the OEM screws look like. Hope this helps
http://forums.maxperformanceinc.com/...am+air+screens
70 Formula 400
69 Grand Prix 428
70 Buick GS 455 Convertible
66 Oldsmobile Toronado
Always looking for more
  #342
Old 07-03-2016, 01:49 AM
Chieftain54 Chieftain54 is offline
Found this same car original owner , she ordered in 69 Trading in a gto ,been sitting since 89 ruff but all there. I hope to do a third of what this resto was.
  #343
Old 07-15-2016, 11:46 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Is it a Ram Air III or standard?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
  #344
Old 07-17-2016, 09:30 PM
It's 4spd a/c car but not ram air, little bit of a bummer. It's the same as the one you had in eBay, did that sell.
  #345
Old 07-18-2016, 10:44 PM
  #346
Old 07-18-2016, 10:46 PM
Original owner car needs plenty of metal work but all there #s matching I was told do homework and make offer, any suggestions .
  #347
Old 07-22-2016, 10:47 PM
Is it really rusty on the bottom side, too? i.e. rear frame rails, floorpan, trunk pan? (I'm guessing with all the holes around the back window that the trunk is also gone).
  #348
Old 07-22-2016, 10:57 PM
No very odd trunk solid and floor pans were solid feeling also, she parked it Around 91 and covered it cover is beat but looks like water pooled up on vynal top trim and rotted through. Needs both full rear quarters rear sail passenger door skin and fender building on drivers side saved that side. She traded in her 68 gto and Speacial ordered this car.
  #349
Old 07-24-2016, 09:33 PM
If the underside can be saved without major surgery, I'd put value at around $2500. It needs a ton of work, but a nicely optioned matching number car with a lot of the original bits is a good starting point ...
If you end up getting it, start a new thread for it-
  #350
Old 07-24-2016, 11:42 PM
Thanks owner will be back in town in two weeks, I'm thinking the same on price. I think she contacted Ames to see if they would like to purchase, at least they have all the parts it will need!
