Old 06-19-2016, 08:53 AM
acgwinn acgwinn is offline
Default BUNCH OF TRANS AM/FIREBIRD PARTS FOR SALE....
Time to clean out the garage of some parts I'm not going to be using for any of my projects. If I don't have a part listed, ask, I may have it. Can't list everything. Prices do not include shipping. Damian.
79 4-Speed Steering Column w/keys. $75
75-81 Rear Sway Bar Setup. Blasted and Primed. Missing one Drop Link Bushing. $75
70/71 RH Grille. Nice shape. All Mounts are good. $45
74-78 RH Taillight. Good Lens. No major cracks. $20
74-78 Taillights-Pair. Nice Lenses. Stress cracks in the clear license plate lens on the RH side. $45
69 Bird LH Fender Gusset. Some Pitting. Not to bad. $20
67/68 Spring Support Metal. New Repro. RH Rear. $20
69 Bird Under Colum Cover. Nice shape. Black. $20
69 Firebird NOS Antenna Lead. $30
67-69 Fender bars. Pair. $15
69 Firewall to inner fender brackets. $20 pair
69 Deluxe Door Pulls W/Base. Need to be redyed. $25 for pair
69 Parking Light Chrome Bezels. Need Rechromed. $15 for pair
70-72 Nuetral Safety Switch Extension Harness. NEW IN PACKAGE. $10
67-69 Radiator Upper Bracket. $15
69 LH Taillight. Good Mounts and lenses. No cracks. $25
69 Driver side Headlight Cushion $20
69 Driver side Headlight Metal Base. $20
70-81 Hood Hinges. $25 for pair
69 Driver Side Bumper to Frame Bracket. $25
69 Fold Down Rear Seat Custom Upholstery. PUI Brand New. $125
67-69 Plastic Seat Back. Tan. Some scuffs, not bad. $15
67/68 Dash Core. Needs to be restored. $30
67-69 Rear 1/4 Glass. Tinted. $50 for pair.
67-69 Passenger Side Rear 1/4 Convertible Glass. $15
67-69 Passenger Side Rear 1/4 Glass. $15
69 Dash Grab Bar. $10
69/70 Timing Chain Cover. $75
69 Hood Latch Setup. $25
67/68 Hood Latch Brace and Bracket. $15
77-81 Lower Radiator Support Brackets. Blasted and Primed. Some pitting. $30 Pair
74-78 Rear License Plate Bracket. Blasted and Primed. $20
79-81 Radiator Support to Nose Brackets. Blasted and Primed. $40 (All 5 of them)
77/78 Radiator Support to Nose Brackets. Blasted and Primed. $50 (All 5 of them)
Dash Prism. Hard to find not broken. $20
70-81 Automatic Shifter Bezel. No cracks or breaks. $40
77-81 Fender to Radiator Support Bars. Blasted and Primed. $15 for pair
70-81 Non A/C "Y" Duct. $20
70-81 A/C "Y" Duct. $20
Catalytic Convertor Exhaust Bracket. Blasted and Primed. Hard to find. $20
79 Taillight Harness. $15
79 Headlight and Taillight Harness. $30
79 Under Hood/Headlight Harness. $25
81 Under Hood/Headlight Harness. $25
70-81 RH Lower Fender Patch Panel. $60
75-81 Pillar Post Trim. Blasted and Primed. $20 for pair
70-81 Tan Under Column Trim Cover. Non A/C. Mounting Holes are nice. No breaks. $25
Old 06-20-2016, 07:41 AM
Kent Christensen's Avatar
Kent Christensen Kent Christensen is offline
Default Parts
I will take the 69 dash grab bar for 10.00 and the 69 deluxe door pulls with bases for 25.00. Do you use paypal?
Old 06-20-2016, 09:16 AM
nocwalker nocwalker is offline
Damian, PM sent
Old 07-17-2016, 02:43 PM
UPDATED LIST:
Old 07-30-2016, 10:38 AM
TTT
Old 08-13-2016, 05:28 PM
I have a lot of other second generation parts available. Never hurts to ask....Damian.
Old 08-15-2016, 02:20 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
OK, I'll ask: 73-77(ish) 4 bbl air cleaner base?
___________________________________
"Objects in mirror are closer than they appear"
Old 08-15-2016, 07:04 PM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Hi Damien,if the chrome surround on the rh [passenger] side grill is good I will take it,thanks, Bruce. PM me.
1970 T/A RA3 #'s match.
Old 08-16-2016, 02:23 PM
Sorry I only have one left at the moment and it's for my car. If I come across another i'll let you know. Damian.
Old 09-05-2016, 05:38 PM
70/71 Grille is sold! Other parts are available.
Old 10-05-2016, 06:12 AM
P.M. me if interested. I don't get notified if someone replies to the thread.
Old 10-05-2016, 12:24 PM
400 4spd.'s Avatar
For a '78 Trans Am, I'm looking for the narrow plastic interior trim that goes along the inside roof and covers the edge of the headliner. Non T-top car, of course. A nice A/C dash is needed, too.
Old 11-02-2016, 01:14 PM
EvilEd EvilEd is offline
Do you still have the under hod headlight harness for the 79 TA. can you send a picture if so. [email protected]
Old 11-03-2016, 05:37 AM
Sent you some pix. Let me know you got them and if you are interested or not. Damian.
Old 11-03-2016, 09:33 AM
thanks Received.
Southwest Pontiac Car Club:
http://edozogar.wixsite.com/el-paso-swpcc
[email protected]
Old 12-12-2016, 09:57 PM
A bunch of parts still available.
Old 03-25-2017, 02:29 PM
TTT
Old 03-26-2017, 01:19 PM
vidguy's Avatar
vidguy vidguy is offline
Damian-
Hi there. I'm looking for the Ground (Brown or tan) wire, connectors and rubber grommet that are in the tank near the hinge for the Sender ground in a 75ish.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-27-2017, 03:22 PM
Originally Posted by vidguy View Post
Damian-
Sorry, I don't have what you need. Damian.
Old 03-28-2017, 04:34 PM
vidguy's Avatar
Thanks anyhow!
James
Work
Details here:
