Old 10-18-2016, 08:04 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Default Brinell hardness of a factory block?
Does anybody know what the brinell hardness of a stock pontiac block would be? I have a chance to buy a blemished IA2 block but it is a little soft at 180 brinell. Do you think it will hold 800-850 HP reliably on the street? Thanks
Steve
Old 10-18-2016, 09:40 PM
You might want to read this paper on Brinell hardness for OEM Blocks.
http://www.afsinc.org/files/images/iron%20alloys.pdf
From what I read 180 barely meets the bottom spec for a cast iron OEM block as far as material strength.
But you still would have a block with 4 bolt mains, (steel caps and splayed outer bolts), thicker cylinder walls, more material in the valley, stronger lifter bore design, etc.
Some years ago a Pontiac family bought some blocks that were not quite up to spec and eventually both blocks had issues, Failed.
That being said, Marty Palbykin (with a 1967 factory block) with splayed caps installed and some block chryo treatment ran a 1600 hp Twin Turbo engine for 3 years before a crack developed. Is the engine NA and what rpm are you assuming?
Old 10-18-2016, 10:25 PM
p4msi1's Avatar
Tom, D1SC procharger street driven, not raced. I am stepping up from stock iron heads to ported edelbrock and do not want to ruin the current 455 assembly. I will turn about 5500 rpms. I was assured this block could hold 800HP but I also don't want it to be an expensive lesson.
Old 10-18-2016, 10:27 PM
Interesting link Tom, thanks for sharing.
Old 10-18-2016, 10:49 PM
Steve C. Steve C. is offline
Years ago the infamous MR-1 "butter blocks" were a minimum 145 and maximum 150
Old information here:
Old 10-18-2016, 11:16 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Steve
Brinell testing is mearly a snap shot. It doesn't take into consideration heat cycles and prolonged load cycles. I've ground on blocks that on the surface seem hard, but once material is removed, you find casting porosity that weakens the block.
Btw, I've not seen any casting or porosity issues with a factory block.
Calvin Hill
Hill Performance
708-250-7420
Old 10-19-2016, 05:57 AM
p4msi1's Avatar
Calvin Hill
Hill Performance
708-250-7420
Calvin,
I'm trying to decide if I should chance my current 455 with a street 800 HP or would this "softer" IA2 be a better option. I might just buy a regular IA2 and just skip this "softer" block. I drive this car out on trips and play with it a lot, the last thing I need to do is break the block when I'm 8 hours from home.
Steve
Old 10-19-2016, 06:22 AM
If there is any one within driving distance( 6 hours) that does cryogenic treating I would take the IA block there , get it treated and then run it!
Old 10-19-2016, 07:02 AM
Robert C.'s Avatar
Robert C. Robert C. is offline
All IAII blocks are 220 ish bernell. We had a foundry use stock cast iron on 4 blocks. 2 are left for sale as a blems. They are not sold as a high end blocks. They are marked blem. But good for a stock to mild engine build. With all the engineering and machine work of a STD race block but normal engine casting marterial. You can't prep a stock block this nice, this cheap. They look great and would be a help to someone who is looking to save a few bucks.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 10-19-2016, 08:01 AM
I do not think that Marty's block would have held together that long had the stroke been longer!
Old 10-19-2016, 08:46 AM
p4msi1's Avatar
Bob,
I guess the ultimate question is will it hold 800 HP reliably. I don't consider 800 HP a mild build. If it will hold it reliably I will send money now!!!!
Steve
Old 10-19-2016, 09:40 AM
Yes/no... At the rpm he was running(7800 iirc) you are probably right. I think differently if a 455 was the base, a much lower rpm could make and sustain the same power level for same amount of use...different turbo's required to do that.
Old 10-19-2016, 11:42 AM
Marty Palbykin Marty Palbykin is offline
Buy a good block it is the foundation.
Because if 800hp is good 1000hp is better.
Good luck
Steve[/QUOTE]
Old 10-19-2016, 12:33 PM
p4msi1's Avatar
Hey Marty, you been seeing my boy, Micah, Lately? Oh, Thanks for the advise.
Steve Prudhomme
Old 10-19-2016, 12:45 PM
Steve Prudhomme
Yes he a good man.
Old 10-19-2016, 02:31 PM
Robert C.'s Avatar
Bob,
Steve
Steve,
If it were me and I was building a good street motor N/A, I would buy it in a minute. That is where the other two blocks went.
But you will be adding a power adder and that is where only you can make that decision.
When you make that kind of power it is like a good feel that just won't stop and you want more and then you want more.
Allpontiac has always stood by its products and will not sell a product with out fully informing the customer as to what they have.
These blocks were made by the foundry by there mistake. We offer them to a customer because some of them just will not build 1k H.P. and want something that is a upgrade but not a Monster of a motor. This is a cost savings.
The other thread was talking about a replacement block made cheaper, is not something that we found we can do. It is the same casting, sand, mold assembly, Shipping and machine work to make a better replacement block or a race block.
This is a one time offer and will never be offered again.
Bob C.
Boss Bird Funny Car
Old 10-19-2016, 03:31 PM
p4msi1's Avatar
Bob, I will contact you a little later.
Steve
Old 10-19-2016, 04:18 PM
Good luck
Steve
[/QUOTE]
So very true Marty, as you well know.
BOOST IS ADDICTIVE! YOU WILL START OUT SAYING IN GOOD FAITH THAT I WILL NOT GO OVER 800 HP. Then the Boost Fever comes and you want 1000 hp or more.
Agree with the NA deal not being as big of an issue because you can't add 300 more hp with just the turn of a screw or pulley change like a boosted deal.
Buy the better block in the beginning for boost.
Old 10-19-2016, 05:25 PM
p4msi1's Avatar
Tom, you and Marty pushed me into a new block, Thanks?
Steve
Old 10-19-2016, 08:50 PM
Calvin,
Steve
It sounds like you are making a good decision.
Calvin Hill
Hill Performance
708-250-7420
