Old 10-23-2016, 09:25 PM
Scott Stoneburg's Avatar
Default Ran good today at Bradenton.
Ran a new best with the D-ports today. 10.55 @129.4 Drove it there and back today had a real good time.
Old 10-23-2016, 09:32 PM
stroker461's Avatar
stroker461 stroker461 is offline
Congrats Scott!!! True10sec street car thats Awesome brotha keep up the good work....
Old 10-23-2016, 09:35 PM
CONGRATS ON YOUR NEW BEST EVER PASS.
I always liked DeSoto Dragway. That was/is Jimmy & Vic Keens Home Track.
If you see them sometime tell them I said "Hello" and I will be retiring from Ford at the end of the year.
Old 10-23-2016, 10:33 PM
Thanks, im pretty happy with the results I'm having with my car. I Haven't seen the Keen in a long time but I do know them my brother knows them pretty well.
Old 10-24-2016, 07:44 AM
gkinch's Avatar
gkinch gkinch is offline
nice job scott!
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
Old 10-24-2016, 07:49 AM
Good job!
Change tires at the track or run the street tires?
Old 10-24-2016, 09:57 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Very cool, driven back and forth.
What's the combo?
Old 10-24-2016, 11:59 AM
Good job!
I drive it on Mickey Thompson ET Street. The new SS tire. They work as good as the old ET Streets did, at least for me.
Old 10-24-2016, 12:41 PM
grandville455's Avatar
Nice Job!!
Darby
M/T 275/60 ET SS Drag Radial
Old 10-24-2016, 12:56 PM
WARPed's Avatar
WARPed WARPed is offline
Good going Scott!!
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 10-24-2016, 01:31 PM
Thanks guys. Alex, I'll most likely be putting the E heads I got from you on after the beginning of the year. Gonna just tune on these and see hi ow fast I can get it before I switch. Hoping to get into the 10.40s I think I could have had it there yesterday. I had 1 run that the 60' was good enough. But on that run I had fuel delivery problem. ( ran out of gas..lol..)
Old 10-24-2016, 02:56 PM
Cool job Scott!
Old 10-24-2016, 04:21 PM
joes455 joes455 is offline
Weight and combo
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 10-24-2016, 04:31 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Very nice sir! That is a bad machine, well done.
Old 10-24-2016, 04:50 PM
455firebird1969's Avatar
If you did that with OEM iron D-ports, that's impressive.
Old 10-24-2016, 06:22 PM
Yes. Ported #62s. Using a victor, no port work to the runners. Actually I had to use epoxy to close up the runners. They were too tall.
Old 10-24-2016, 08:27 PM
66bonne's Avatar
66bonne 66bonne is offline
Great to see you out again Scott. That Fbird looked strong all the way down the track.
Jim
Old 10-24-2016, 09:01 PM
Wow 10.50s @ 129 MPH is NICE Iron performance. Sell the E-heads, keep the Canolis.
Old 03-16-2017, 10:22 PM
Made it to the 1/8th mile track last night. Weather was good. And with a little tuning I got it to run 6.54 @ 104.26mph. Incremental were.
60'......1.47
330'....4.20
1/8.et..6.54
1/8mph..104.24
Pretty happy with the performance.
Old 03-16-2017, 10:27 PM
360Rocket's Avatar
360Rocket 360Rocket is offline
Congrats Scott, the DA's had to be incredible with the cold air we are experiencing.
