Old 11-14-2011, 10:00 PM
Cool looking car.
Glad you made it back OK.
Will be waiting on more pics.
  #42
Old 12-06-2015, 10:56 PM
165th's Avatar
165th 165th is offline
Well, after 72 distractions over the last few years (pun intended) , it's time to focus on 'Sister.' Sister was purchased back in 2011 and worth saving so, after purchase she was put on the back burner. Well it's finally her turn.
The last few projects were pretty intense, so we are going to have a little fun with this one. I stress 'a little' but it will be fun.
Back when, and thanks to RAFormulas the anchor component of the interior was sourced, namely the 'pizza stand' 8-track mounting bracket specific to these super rare and highly sought after column shift TA's. More recently, Jim Robertson from these forums took a peak into the numbers matching YE 455HO and gave a thumbs up that the engine can be saved (more on that later) so that anchored the engine bay.
So what better place to start than the beginning! Here we goooo!!!
ID:	415016   Click image for larger version
ID:	415017   Click image for larger version
ID:	415018   Click image for larger version
  #43
Old 12-07-2015, 12:41 PM
4birds's Avatar
4birds 4birds is offline
Thumbs up
Subscribed.
This one should be much easier to reassemble!
Go Greg Go!
  #44
Old 12-11-2015, 03:57 PM
Alvin's Avatar
Alvin Alvin is offline
Subscribing
  #45
Old 12-15-2015, 05:34 PM
unruhjonny's Avatar
I was pleasantly surprised to see this thread bumped!
1970 Formula 400
  #46
Old 01-01-2017, 02:42 PM
165th's Avatar
Happy New Year to the Forums.
Another year has gone by so it must be time to update this thread.
Jim Robertson from the forums has been working on the YE engine for this car. He call recently and said the engine was ready to dyno. Yay.
Before going into the results of the dyno session here's a bit of a backstory. To say this car had been mistreated in a previous life is an understatement.
Pictures speak for themselves, but it was obvious the YE was home to a family of critters at one time. The first picture is what I came upon the day we picked up the car. Thank goodness the Moroso??? valve covers oil cap openings were taped over to prevent moisture from getting in the engine!!
Then, during engine teardown, a few more surprises were found. Not only were the pistons frozen in the cylinders, but the layers of rust in the bottom end were enough to scare even the most optimistic that this engine might not have a chance of coming back from the dead.
But, after a few months soaking in Liquid Wrench things loosened up, the teardown was completed, and it was time to see if she could be resurrected.
Name:	72 TA Sister 101 s.jpg
ID:	443767   Click image for larger version
ID:	443769   Click image for larger version
ID:	443770   Click image for larger version
Name:	455HO 103 s.jpg
ID:	443771   Click image for larger version
  #47
Old 01-01-2017, 02:57 PM
165th's Avatar
Engine rebuild was tedious and meticulous. Things started looking up for the YE until finally dyno day arrived December 29, 2016.
This is my second engine to be built by Jim. The results for the YE are extremely similar to the '72 TA WD that we dyno'd in 2013. Those results are posted on page 93 of the 455 HO Forum:
http://forums.maxperformanceinc.com/...538654&page=93
During our day in the dyno, in addition to recording the results of the performance of the YE, we also did some experimentation with exhaust equipment testing OEM manifolds, Hooker Super Comp. headers and the infamous Ron Watt Tribal Tri Y headers. Those results will be posted in a new thread on the forums in the coming days.
Finally, results for the YE:
7042270 carb with CE rods (CR is stock but the engine ran lean so CE's helped by about 10HP)
38 degrees BTDC timing
Horsepower: 475 HP Torque: 541 ft-lbs
We could not be happier with the results. An unbelievable build. Thank you Jim Robertson!!
https://vimeo.com/197687895
https://vimeo.com/197688223
https://vimeo.com/197688407
Name:	455HO 111 s.jpg
ID:	443775   Click image for larger version
Name:	455HO 110 s.jpg
ID:	443776   Click image for larger version
Name:	4 bolt main s.jpg
ID:	443777   Click image for larger version
Name:	dyno 122916 1.jpg
ID:	443778   Click image for larger version
Name:	dyno 122916 4 s.jpg
  #48
Old 01-01-2017, 03:19 PM
Nicely saved!
  #49
Old 01-01-2017, 03:20 PM
72projectbird's Avatar
Wow, that block looked bad! I thought my rust 400 block I have was destined to become a coffee table, but if you managed to save that, maybe I can save mine?
Those are some killer numbers! The car should be a blast!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #50
Old 01-01-2017, 03:31 PM
Norwood's Avatar
Norwood Norwood is offline
Some great numbers there. Think you might drive this one a bit more than the last one ?
  #51
Old 01-01-2017, 03:44 PM
Pepi's Avatar
Pepi Pepi is offline
Nice saving of that engine. Wow, I haven't pulled any apart myself but that looked ugly.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #52
Old 01-01-2017, 10:21 PM
Formulabruce's Avatar
QUOTE" 38 degrees BTDC timing
Horsepower: 475 HP Torque: 541 ft-lbs"
on "CR is Stock"
THis, is impossible at 8.2, or 8.4:1 .. IMHO... Block decked? , Pistons have under 5 cc relief's ?, Height in cylinder>? Whats the Pressures at?
Not trying to Diss on it, I absolutely Love it.. but..... its a 330 HP engine
" Long may we DRIVE !"
  #53
Old 01-01-2017, 11:03 PM
165th's Avatar
on "CR is Stock"
Just a clarification, my reference to CR is the carb jetting. We changed from CR rods to CE rods to rich the fuel mixture.
Compression ratio is stock around 8.4. The block is not decked.
Reading the posts on page 93 of the 455HO Forums is a good starting point for how it's done.
Balanced rotating assembly. A great valve grind. 1.65 rockers, a custom designed cam grind, some head porting to improve cfm flow. Those are some of the improvements done. There is more but the rest is over my head. Maybe Jim can chime in and explain some of the other tweaks to reach this power. One thing I can assure you, it's not impossible. The results speak for themselves.
  #54
Old 01-01-2017, 11:11 PM
OPPS! My bad, damn sorry, wasnt trying to be rude, I guess im just not paying attention!! I will be doing the reading!! Thanks for clearing it up
  #55
Old 01-01-2017, 11:15 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
congrats Jim and Greg! The numbers are incredible and that torque curve is going to be a lot of fun!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #56
Old 01-06-2017, 12:16 PM
unruhjonny's Avatar
wow!
that bottom end was a mess!!
1970 Formula 400
  #57
Old 01-06-2017, 05:03 PM
The Boss's Avatar
The Boss The Boss is offline
OMG
And go racin' in the street.
