Old 11-19-2016, 12:16 AM
Originally Posted by fyrffytr1 View Post
67 GTO with 17" YearOne rally IIs, 4.5" backspacing. Tires are 235/50R17 Eagles. I had to trim the rear fender lip flush with the wheel well trim and raise the car 1" for clearance. This is with the stock 67 rear end.
I also had to work on the fronts a little. There is a bump out in the back of the driver's side fender liner that I had to use a hammer on and I had to loosen the back fender bolts and ease the fender out a little for clearance.
Looks great on your car!! Congrats on getting them.
  #222
Old 12-26-2016, 05:43 AM
wim firebird's Avatar
wim firebird wim firebird is offline
Default ...
AEZ Bimmer rims front 18x9 with Michelins PS2 255x40/18 rears 18x10 with PS2 295x35/18
  #223
Old 12-26-2016, 11:43 AM
Zyman's Avatar
Zyman Zyman is offline
[QUOTE=wim firebird;5673488]AEZ Bimmer rims front 18x9 with Michelins PS2 255x40/18 rears 18x10 with PS2 295x35/18
Questions. Did you mini tub the rear? What are the offsets of front and rear rims, any rubbing issues?
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
  #224
Old 12-27-2016, 07:13 AM
[QUOTE=Zyman;5673549]
Yowww! nope, no mini tub, but its a tight fit ...offsets are ET6 on the front and ET15 on the rears,,Rubbing? sometimes ...
  #225
Old 01-02-2017, 11:03 PM
gixxer711 gixxer711 is offline
Specs in sig below.
The Following User Says Thank You to gixxer711 For This Useful Post:
  #226
Old 01-02-2017, 11:23 PM
Zyman's Avatar
[QUOTE=gixxer711;5677303]Specs in sig below.
Nice! What rims are those? Kind of look like ones Dave at PTFB recommended that I cannot find my notes on.
  #227
Old 01-03-2017, 12:59 AM
69FIREBIRD76MM's Avatar
Originally Posted by hdpontiac View Post
i posted this on the forum in different threads and got no replies so I'm trying this thread I have a 1969 gto with 15x5 front and 15x8 rear the rims are weld rims front is 3-1/2 back spacing and rear is 4-1/2 back spacing I like to run street tires on the car I need to get the correct front tire with no issues of rubbing the rear is 275-60-15 any help is appreciated
You can go 205-70-15 or 215-70-15 on your 5" wide rims, tire is about 26" tall.
  #228
Old 01-03-2017, 11:38 AM
Thanks! They are US Mags Rambler
http://us-mags.com/rambler-u111-w-6133.htm
  #229
Old 01-03-2017, 04:21 PM
I just remembered that it is the Vision Torque that Dave at PTFB recommends. He says they have more brake clearance. I prefer the flat face of the US Mags though.
http://www.visionwheel.com/wheel/14894/2831/
  #230
Old 07-06-2017, 12:40 PM
highrisk's Avatar
highrisk highrisk is offline
Here is what I finally ended up with for my 1965 GTO. Wheels are American Racing Hopster Chrome 17" wheels. The front are 17x7 with 4.75" backspace and Kumho Solus TA71 215/55/17 tires. American Racing recommended 4.5"BS with these tires and wheels on this car and then I increased that by .25" for front disc brakes. Since my engine has a lot lot of aluminum I cut one full coil off of stock MOGG 5244 front coils (stock 4 speed with A/C springs).
The rear are 17x8 with 5.75"BS and Kumho Solus TA71 245/50/17 tires. American Racing recommended 5"BS with these wheels and tires on this car. I then increased that by 1/2" for a later model rearend (wider) and 1/4" for disc brakes. The rear coils are original MOGG for a 1965 GTO convertible (I believe they are 5237 but am not sure).
The shocks are KYB Gas-A-Just shocks and I am running the stock upper and lower A arms in the front with boxed lower arms in the rear. The front sway bar is 1 1/8" and I added a 7/8" rear sway bar and the frame reinforcement braces in the rear. The steering gear box was rebuilt with quick ratio gears out of an IROC-Z.
Dale
Name:	P1060741 - Copy.JPG
ID:	458217   Click image for larger version
Name:	P1060744 - Copy.JPG
ID:	458218   Click image for larger version
Name:	P1060756 - Copy.JPG
ID:	458219   Click image for larger version
Name:	P1060758 - Copy.JPG
Tremec 5 Speed
U.S. Army Retired
Retired Helicopter Pilot
  #231
Old 07-06-2017, 12:42 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
LOOKS GREAT
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #232
Old 07-06-2017, 03:37 PM
linden_gto's Avatar
linden_gto linden_gto is offline
recently added 15" eliminators - 7s and 8s - and wide oval redlines. F70 fronts, G70 rears.
ID:	458229   Click image for larger version
ID:	458230   Click image for larger version
'67 GTO
'97 993 C4S
'86 951
'05 V70R
  #233
Old 07-06-2017, 05:55 PM
The Boss's Avatar
The Boss The Boss is offline
Ronals anyone?
And go racin' in the street.
  #234
Old 07-06-2017, 05:59 PM
highrisk's Avatar
Originally Posted by AdamIsAdam View Post
LOOKS GREAT
Thanks Adam, hope all is well.
Dale
Tremec 5 Speed
U.S. Army Retired
  #235
Old 07-31-2017, 04:20 PM
AdamIsAdam's Avatar
Dale
Hey folks. So guess what? I checked when I had ball joints done last month and my front springs were both not seated correctly. I had them properly set in place and that lowered the front end A LOT. So much so that now my front tires rub on the bolts to the chrome fender trim on bumps while the wheel is turned.
I've got 215/60x15 BFG's on there mounted on Cragar S/S 15x7 with 4" BS.
My question is this: If Carl's 4.75" BS wheel with 215's doesn't rub but my 225's with 4" BS does, what size tire should I change to in order to alleviate the rub? Is 215/70 going to clear? I wanted 205/70 but it doesn't look like they make that size so I'd have to change brands I guess, but I like the BFG RWL look. They also make 215/65 but I think I'll need to go down to 205. Not sure.
And I don't mind raising up the front a bit since my rake it more severe than I like now. Rears are 275x50.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #236
Old 10-07-2018, 02:25 AM
ramairthreegto's Avatar
ramairthreegto ramairthreegto is offline
So, there are factory 14 and 15 inch rallye II wheels,
Are there 16 and 17 inch aftermarket ones?
I plan on going to 15s and not stagger on the 70 GTO,
I hate how these cars look with 18s.
Any good profile pictures of a 70 with the 16 or 17s?
"Yes, it's a real GTO. I know the scoops, spoiler, exhaust tips, and rear wheels are wrong. Umm, sure it's the 'big block' 400, you are quite the expert. I am driving in the rain, at night, running errands, with the kids who are eating and having ice cream in the back, after going to the drag strip, burning rubber, and blowing donuts. Do you really think it's numbers matching all original?"
  #237
Old 03-15-2019, 09:37 AM
JamesR913 JamesR913 is offline
I have a 66 GTO I am doing a frame off restoration of and and getting ready to start putting the suspension and such back on the frame. I am going the restomod-ish route with after market control arms and disc brake conversion all around. I am putting in springs with a 1" drop all around due to the aluminum LS motor going in. My brake conversion spindles are stock ride height and I am planning on running 15 x 7 rally II wheels with a 4 in back space, to make it look somewhat stock. My question is regarding tires. Looking at sizes is really confusing, would 235/60- 15 work or is that too wide? Any help would be appreciated.
Sent from my ONEPLUS A6013 using Tapatalk
  #238
Old 03-15-2019, 07:53 PM
amcmike's Avatar
amcmike amcmike is offline
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
  #239
Old 04-14-2019, 07:25 AM
Mudtrux's Avatar
Mudtrux Mudtrux is offline
Originally Posted by nac46 View Post
For those interested in an old school approach to tire/wheel combo for 61/62 Cats, I've elected to go with 80s GM truck ralleys (15x7) and mounting 235x70R rear and 225x70R front. No clearance issues. It works.
I know this is years old, but do you have a pic of your car with these wheels were on it?
Thanks.
  #240
Old 04-14-2019, 05:45 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Jegs Sport Torque's 17x8 with 235/45R17's all the way around, stock spindles, front and rear QA1 coilovers. Crappy pic, but I am dealing with a brake issue and havent had the car out much this year as I have been troubleshooting that....
Rims here.
https://www.jegs.com/i/JEGS/555/670046/10002/-1
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
