Old 02-02-2017, 04:38 PM
64speed's Avatar
64speed 64speed is offline
Default Anybody ever use these
And if so what was the benefit
https://www.moog-suspension-parts.com/moog-k5250
Old 02-02-2017, 05:03 PM
Sirrotica's Avatar
Although I have never used them, the benefit is allow more adjustment for alignment. Older frames have a tendency to twist over many miles not giving you enough latitude to get the alignment within specs. The offset shaft moves the pivot center on the upper A frame without having to resort to pulling the frame to get it back to the original factory specs.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 02-02-2017, 05:49 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
That's what I was told when I brought my old Firebird to the alignment shop.
67 Firebird Convertible
Old 02-07-2017, 04:19 PM
First Bird's Avatar
First Bird First Bird is offline
Used these effectively on my 1968 Firebird.
- Tom
Old 02-15-2017, 12:39 AM
64speed's Avatar
Did you notice a difference? Did it come with improved alignment specs?
Old 02-16-2017, 11:27 PM
First Bird's Avatar
It's been a while since I did this. I had been told that my frame had sagged and that made it difficult to shim for alignment properly. I got my specs from http://www.pozziracing.com/first_gen...gnment%20specs
I think I'm running -1.3 Camber, +4 Caster and 1/8 toe in
- Tom
Old 02-16-2017, 11:29 PM
First Bird's Avatar
See if you can get the alignment you want with stock shafts. If not, then get the offsets
- Tom
Old 02-17-2017, 01:13 AM
FrankieT/A's Avatar
They are called "Problem Solvers". Here's the quote right off the link you provided.
Front Control Arm Shaft - Chevrolet Camaro
Fits Left or Right Side. Offset Shaft Kit Provides Additional Camber Adjustment of up to 1-1/2 degrees
Old 02-17-2017, 04:40 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
Yeah, I used them on two of my cars, and they are great.
Build it fast, build it right, hold On TIGHT !!!
