Old 03-03-2017, 10:57 AM
Poncho-V's Avatar
Poncho-V Poncho-V is offline
Doug, this is a 4 cyl. tach that needs refurbishing. I have done some cleaning on it. It is 4 cyl. only from Sun. Check the pic of the back of the housing.
  #142
Old 03-04-2017, 05:04 PM
Doug Doug is offline
Smile tachs
I couldn't tell from your pics if it was similar to an old Dixco tach that could easily be changed from 8 to 6cyl.
Thanks!
Name:	DSCN3910 (1000x750).jpg
  #143
Old 03-24-2017, 03:48 PM
heater63's Avatar
heater63 heater63 is offline
Originally Posted by heater63 View Post
I am looking to sell my 63 Pontiac 336 cu
I have recently had it rebuilt by a trusted and reputable machine shop here in Ontario. There is honestly less than 500 miles on this motor, I have always ran Brad Penns Green oil in it and changed that every season.
I believe I will be able to find the build sheet from the machine shop but will list a few things that were done to the motor.
30 over
Egge pistons
New water pump / RARE
Mild street cam / Comp cams (will find cam card as well
New oil pump
Point ignition
Triple angle valve job
Rebuilt heads
No alt or carb
The only reason I am selling is moving up to a 455. And know it would just sit on a stand for years and not do anything with it.
I am located in Ontario Canada but could ship from Niagara Falls NY or possibly meet.
$2000 o.b.o.
[email protected]
519-719-4875
Thanks for looking,
Heath
Sold
"If you aren't first, your last." Ricky Bobby 2006
  #144
Old 03-26-2017, 07:52 PM
Peter Serio's Avatar
Default 1963 Lemans in Dash Factory Tach
For sale one original 1963 Tempest or Lemans Tach. Very clean. Meter is fine; electrical circuit has an issue. I am going to take it apart and repair. Since these tachometers have a sealed circuit board I am going to remake the circuit package.
As buyer wishes I can rebuild this to work on either a 4 cyl or a V8 engine. It works off of the stock distributor (points only). You much have the original distributor in your engine with points for this to work.
A 4 cyl tachometer for a '63 Tempest is very rare; I have only seen 2 in my lifetime.
Price is $495
Name:	1963 Lemans in Dash Tach_PYs.jpg
ID:	450745   Click image for larger version
Name:	1963 Lemans in Dash Tach_PYs 1.jpg
ID:	450746   Click image for larger version
Name:	1963 Lemans in Dash Tach_PYs 2.jpg
ID:	450747   Click image for larger version
Name:	1963 Lemans in Dash Tach_PYs 3.jpg
ID:	450748   Click image for larger version
Name:	1963 Lemans in Dash Tach_PYs 4.jpg
Peter Serio
Owner, Precision Pontiac
  #145
Old 05-16-2017, 07:03 PM
ronk455's Avatar
ronk455 ronk455 is offline
Default 61-62 Tempest top of rear quarter trim pieces
These fit 61 or 62 Tempest. One side has a dent, the other side is untouched.
$40.00 plus shipping
ID:	454720   Click image for larger version
ID:	454721   Click image for larger version
ID:	454722   Click image for larger version
  #146
Old 05-16-2017, 07:06 PM
ronk455's Avatar
Default 61-62 2 spd automatic valve body
Removed from my 62 Tempest 2 speed auto.
$50.00 plus shipping
ID:	454724   Click image for larger version
ID:	454725   Click image for larger version
  #147
Old 05-17-2017, 11:07 PM
blueghoast's Avatar
Aren't they identical from side to side, If so I'll take em
GT.
  #148
Old 05-18-2017, 11:32 AM
ronk455's Avatar
PM sent to blueghoast
  #149
Old 05-27-2017, 06:34 PM
blueghoast's Avatar
Sorry about the delayed response.
I'll send you a PM.
GT.
  #150
Old 06-07-2017, 08:25 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
I have some parts that I know I will no longer need so I'm just wondering how much interest there is. I have a 3 speed tranny, torque tube with shaft intact, 3 speed shifter complete, clutch/brake pedal assembly with clutch linkage, complete front engine cradle with steering and brake components. There are fined drums on that. Everything is from a V8 car. Shoot me a PM.
  #151
Old 06-10-2017, 08:47 PM
Poncho-V's Avatar
Default '63 326HO Transaxle and torqutube with shaft.
I bought this with the '63 326HO engine with the intention of using it, but I've changed plans. It's just sitting here in the way. Make an offer. Located at 99336.
  #152
Old 06-10-2017, 09:20 PM
higgenslake higgenslake is offline
What ratio?
  #153
Old 06-29-2017, 06:10 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default 61-63 Parts For Sale
$45 each + shipping. Blue Aqua and Red. Excellent condition.
  #154
Old 06-29-2017, 08:09 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
elefantrider,
Do you have any of the lower corner trim pieces for sale?
Thanks,
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
  #155
Old 06-30-2017, 01:13 PM
Default variety of small parts
I have many parts available for sale.
Upper ball joint 61-63 Moog K5048 $25
Tie rod end sleeves, 2 available, Moog ES-6195 $20
used rear shoes from '63 Lemans, lots of life yet, $40 for all pictured
Fuel tank sender unit with gauge float, excellent condition, $40
All prices in US funds. Shipping costs not included.
I also have used rear wheel cylinders for rebuild as well as the repair kits. PM me for details.
ID:	457888   Click image for larger version
ID:	457889   Click image for larger version
Name:	rear shoes.jpg
ID:	457890   Click image for larger version
Name:	sender and float.jpg
  #156
Old 07-01-2017, 02:12 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default Engine for sale
Not mine- on http://landracing.com forums under "For Sale by Individuals" is a slant four built for landspeed racing. Naturally aspirated, injected (gas or alky), complete. $5,000.
  #157
Old 07-01-2017, 04:38 AM
Drag Star Le Mans's Avatar
Thanks Jack! I have it listed here also...
http://forums.maxperformanceinc.com/...d.php?t=806419
DragStarLeMans
  #158
Old 07-04-2017, 10:03 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Doors doors doors
I have all 4 doors from my parts car, will work on a 4 door or station wagon 1963. These doors are in great condition. I have more photos. Make me an offer, the shipping is the hard part of the deal.
ID:	458139   Click image for larger version
ID:	458140   Click image for larger version
ID:	458141   Click image for larger version
  #159
Old 07-15-2017, 11:53 AM
Poncho-V's Avatar
Sun tach for 4 cyl. I was going to have this refurbished and use it in my '63 Coupe, but I'm changing directions on the car and will be going with a V8. Can't remember if I've listed it here or not. Make me an offer.
ID:	458792   Click image for larger version
ID:	458793   Click image for larger version
ID:	458794   Click image for larger version
ID:	458795   Click image for larger version
  #160
Old 08-26-2017, 09:08 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
1963 326 out of my Lemans.
Rebuildable long block, engine code 600, free to whoever can come and get it
