Old 05-04-2017, 09:36 PM
Pepi's Avatar
Pepi Pepi is offline
Originally Posted by 64speed View Post
Use the 13 dollar neoprene reusable gasket from Mr. Gasket that they keep on the shelves at advance auto etc. I have been using one for years on just about every kind of engine besides Ford 😂 And have never lost a drop at the thermostat housing. It's metal with an orange neoprene core.
I have never seen that before. Interesting Do you put it on dry or use anything on it?
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #42
Old 05-06-2017, 11:54 PM
64speed's Avatar
64speed 64speed is offline
It goes on dry. It's reusable too. My Advance has it out on the performance aisle. It's listed for a Chevrolet but it works fine for a Pontiac. I have been using this one I have now for over a year with three thermostat replacements on it. Part number is 738g and it's only 8 bucks on Amazon
  #43
Old 05-06-2017, 11:55 PM
64speed's Avatar
Mr. Gasket 738G Water Outlet Gasket https://www.amazon.com/dp/B000CMF20O..._DQPdzbXENPBCE
  #44
Old 05-07-2017, 08:07 AM
Pepi's Avatar
Alright, I just ordered one from Amazon to have around for future in case I need it. hopefully not though.
Thanks,
Karl
  #45
Old 05-12-2017, 07:23 AM
Pepi's Avatar
Default Doesn't fit my Pontiac
So it came in yesterday and I tried it on my housing and the holes are too far apart on the Mr. Gasket part. I suppose I could try to machine out the holes in the Mr. Gasket part, because those don't need to be sealed. My bolt holes, the one is blind and the other goes all the way through to the bottom of the intake, neither go into the coolant. I am pretty sure, I will double check later today. Only concern would be not having that built up seal around bolt holes could cause housing to warp by pulling down on mounting ears.
  #46
Old 05-13-2017, 06:59 AM
chrisp chrisp is offline
That is not for Pontiac . use the correct gasket .
  #47
Old 05-13-2017, 08:33 AM
Pepi's Avatar
I know it isn't for Pontiac, but it was stated that it worked on Pontiac, so I thought I would try it. I wish they would make one like this for Pontiac.
  #48
Old 05-13-2017, 12:24 PM
Held for Ransom's Avatar
https://www.summitracing.com/parts/s...s/make/pontiac
This one says it does.
  #49
Old 05-13-2017, 12:59 PM
1968GTO421's Avatar
Glad to know this, Thanks! Hope it helps the OP.
GTOAA--https://www.gtoaa.org/
  #50
Old 05-13-2017, 01:26 PM
Thing is, is that I can't believe it's not the same 738G part.
  #51
Old 05-13-2017, 03:17 PM
Grand73Am Grand73Am is offline
It also says it fits Olds, and it definitely would not. A guy in the reviews said it didn't fit his Pontiac 428 due to the holes being too far apart, so at the least it looks like it would need modification for a Pontiac.
Steve F.
  #52
Old 05-13-2017, 05:16 PM
grivera's Avatar
grivera grivera is offline
I had a tricky t-stat leak and cured it with this: https://www.google.com/url?sa=t&rct=...UXZq_FJtv7ms-A
It looks like the Ultra Gray and is much easier to remove than the Right Stuff too.
Will Rivera
  #53
Old 05-13-2017, 08:57 PM
Interesting, and made for that specific purpose. Thanks for the tip!
Steve F.
  #54
Old 05-13-2017, 09:40 PM
NeighborsComplaint's Avatar
Probably fits the later model Pontiac "corporate" (Chevy) small block so some ad writer assumes it fits all Pontiacs.
