Old 06-03-2017, 09:25 PM
ricks63 ricks63 is offline
Default 71 TRANS AM FRONT SWAY BAR VALUE
Can someone give me a idea of what a 71 Trans Am front sway bar is worth? Thanks appreciate the help.
Old 06-03-2017, 10:08 PM
77 Canamman's Avatar
The '70-'81 1.25" front Trans Am bars normally sell for $60-$110 depending on pitting, finish, and wear.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 06-03-2017, 10:23 PM
Norwood's Avatar
Norwood Norwood is offline
Wear?
Old 06-04-2017, 12:03 AM
bird72's Avatar
bird72 bird72 is offline
I recently bought one from a member. It was fresh powdercoated and nice at $125, which I considered a great buy.
72 Bird
Old 06-04-2017, 09:57 PM
Thumbs down
Originally Posted by Norwood View Post
Wear?
I have seen front bars worn where the frame bushings are.
Old 06-04-2017, 10:08 PM
Norwood's Avatar
The rubber wears out the steel? Again I learn something new
Old 06-04-2017, 10:12 PM
You have never seen grooves worn into harmonic balancer hubs???
You need to get out more.
Old 06-05-2017, 03:01 AM
Norwood's Avatar
Very good analogy I would say. A harmonic balancer makes an infinant amount of revolutions vs a sway bar that has very limited movment. Good one , I'm going to make sure I check my sway bar for excessive wear. Lol
Old 06-05-2017, 05:01 AM
Thumbs down
If it's worn, I'm sure your buddy Burd has a nOS bar for five thousand dollars..
Old 06-05-2017, 07:55 AM
Judge273's Avatar
Judge273 Judge273 is offline
I'm thinking there's more to this thread than sway bars? Better get some popcorn...
Mike/Illinois
Old 06-05-2017, 08:03 AM
If you can see the ground out your windows as you turn, your sway bar is wallowed out.
Burd doesn't have a NOS swaybar. We know this because he hasn't told us he does.
Old 06-05-2017, 11:42 AM
72projectbird's Avatar
Sweet! I have a bunch of them kicking around, along with the rear bar.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-05-2017, 01:23 PM
njsteve's Avatar
njsteve njsteve is offline
I'd love to upgrade the original 1" front and 9/16" rear bars in the Gramma car if anyone has a set of big bars to get rid of. And yes, the original front has wear marks where the original bushings trapped road dirt and ground away the outer finish over 42 years of driving. :-)
Old 06-05-2017, 07:35 PM
marxjunk marxjunk is offline
Steve i have a set off a 79 formula...i dont think they are bigger on the rear are they?
they do wear...the brackets cut the bar with age and neglect...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 06-05-2017, 08:45 PM
njsteve's Avatar
Yes, I believe the rear bar is 3/4" on the T/A and the Formula with handling package.
Old 06-05-2017, 09:13 PM
Originally Posted by njsteve View Post
I'd love to upgrade the original And yes, the original front has wear marks where the original bushings trapped road dirt and ground away the outer finish over 42 years of driving. :-)
I've seen some that were surprisingly worn down in the bushing contact area, too..
I sort of wondered how that could be, but I think it comes down to a couple things:
1) The bar moves a LOT... every little bump in the road results in some small rotation of the bar at the bushing.
2) Once they get some grit caught in between the bar and the rubber bushing, whether it's rust or sand or whatever..., the grit tends to "stick" in the rubber, and thus the rotation ends up being between the bar and the non-moving grit.
Or it could be a result of something completely different...
Old 06-05-2017, 09:56 PM
hmmm..lemme look..
Mark..
The Goat whisperer
Old 06-05-2017, 10:08 PM
Some of the fillers used in the rubber compound are very hard elements, like carbon black and silica. Also, particles like salt and silicon can get between the bushing and the shaft surface.
Old 06-06-2017, 07:17 AM
Norwood's Avatar
All good points but the next time I hear someone say my sway bar wore out will be the first time.
Old 06-06-2017, 11:41 AM
Speaking about sway bars wearing out, when I had my front bar removed for new bushings and a coat of paint, I noticed the frame had a small tear under the driver side between the two mounting bolts for the bar. Funky stuff, as it wasn't really rusted.
I guess the car had a rough life before I obtained it lol.
1987 Grand National
