Old 07-09-2017, 02:22 PM
GTOGEORGE's Avatar
Default Oil Pumps
So I've been going crazier then normal trying to get my oil pressure where i want it (I've had my pan off 3 times. I changed my oil pump to the Butler Pro 60 psi pump and been fighting it for 3 days now. Its a GOOD pump thats not the problem it just differs from all the other pumps I've used specially the pump I just took out. Just trying to get good pressure at idle and 70 psi in the end. Its just crazy how different oil pumps can be that have the SAME cast housings and springs. Don't know how the guys without tube chassis /and or not a two piece old pan do it! Thank Gosh I have a hoist!
GTO George
Old 07-09-2017, 02:47 PM
GTOGEORGE's Avatar
I'm about ready to go back to a Mellings pump!
GTO George
Old 07-09-2017, 04:11 PM
wrench's Avatar
wrench wrench is offline
Cool story?
Old 07-09-2017, 04:43 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
The Titan is adjustable and doesn't need a 2 piece pan, just put a plug in the side to adjust the pressure. You would need a modified pan in order to fit the pump in though.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 07-09-2017, 05:01 PM
johnta1 johnta1 is online now
If it's a 60 PSI pump how would you get more than that out of it?
455 SD's were 80 PSI
Old 07-09-2017, 06:03 PM
Change regulator spring or shim it or modify spring cap so you can make it adjustable.
Old 07-09-2017, 06:15 PM
ONLY difference between the 60 psi oil pump and the 80 psi 455 SD oil pump is about $5.00
in two parts. A longer (higher pressure spring) and a longer spring housing.
Last time I bought the stuff from Melling The housing was about $2.00 and the Spring $3.00
Rest of the pump is IDENTICAL. Tom V.
Old 07-09-2017, 06:24 PM
That's right, so why buy a 60 PSI (probably at more money) if you want 70 or more?
George just buy the good Melling pump and worry about other stuff.
Old 07-09-2017, 06:27 PM
This might be of interest:
http://www.luhnperformance.com/pontiac.html
A fwiw, I was recently told of a issue with a modified oil pump sold by Butler. And it was discussed with and confirmed by someone at Butler Performance.
I do not have specifics if it was their Pro pump model.
Old information here:
Old 07-09-2017, 06:34 PM
The Luhn Pump has a lot of pump features not found in your basic Melling Oil Pump stuff.
In George's case he probably is not spinning the pump high enough, Steve, to get into cavitation of the inlet but the other features are all really nice.
I have two of his modded pumps.
Old 07-09-2017, 06:36 PM
Those look like a great pump, more volume and bigger intake pipe.
Old 07-09-2017, 06:41 PM
I did a edit on my previous post since for now I'm not sure if it was their Pro Pump in question. I do know a issue was acknowledged at Butler.
Tom, PM sent
Old 07-09-2017, 06:49 PM
GTOGEORGE's Avatar
Well the thing is I probably wasn't going to get 60psi out of their (Butler) pump.....maybe.......maybe 55, only had 45 at 3000rpm. Now with my Mellings 54d pump I had 70psi, if I'm not mistaken it came with an extra spring (purple), so I installed the spring.
GTO George
Old 07-09-2017, 07:00 PM
GTOGEORGE's Avatar
Ive changed springs and also I've shimmed the spring (changed caps).....at one time i had 100psi with the same configuration I had in my mellings pump (purple spring)! The Butler pump comes with the same yellow spring thats in the mellings 60psi pump. So I took the mellings cap off and reinstalled the Bultler cap (one cap is deeper then the other), with the same purple spring that was in my mellings pump....now I'm only getting 45psi and that it. Just doesn't make sense psi should be at least 70?
GTO George
Old 07-09-2017, 07:21 PM
Originally Posted by GTOGEORGE View Post
The Butler pump comes with the same yellow spring thats in the mellings 60psi pump. So I took the mellings cap off and reinstalled the Bultler cap (one cap is deeper then the other), with the same purple spring that was in my mellings pump....now I'm only getting 45psi and that it. Just doesn't make sense psi should be at least 70? GTO George
If you have the Deeper Cap (probably the stock Melling Pump Cap on the pump and the Butler cap is shallower (with the same spring to compensate for the smaller ball installed in the Butler Pumps so debris does not hang them open) you basically put even less preload on the spring so the pressure went even lower.
You should have shallow cover, smaller diameter ball, and purple spring stock from Butler.
Then if you add a spring washer shim to that set-up you should be able to bump the oil pressure up even a bit more.
Old 07-09-2017, 07:34 PM
Gary H's Avatar
Gary H Gary H is offline
As you know, more to oil pressure than just the pump. Did you change bearings, or grind the crank? Also, if you want a little more psi, you can run a little heavier oil.
Old 07-09-2017, 07:39 PM
The longer housing requires a longer spring.
The longer spring can be stronger because there is room for more coils.
About like valve coil spring installed height.
Also with a short spring in the longer housing it may not be doing anything?
(unless shimmed a lot for the extra length of housing)
Old 07-09-2017, 08:40 PM
GTOGEORGE's Avatar
Nope, everything is the same except oil pump.
GTO George
Old 07-09-2017, 08:42 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I don't normally hang around the race section but what about the Precision pumps?
http://stores.precisionoilpumps.com/pontiac/
Old 07-09-2017, 08:45 PM
GTOGEORGE's Avatar
The purple spring for the melling pump is a 70 psi spring, the yellow is 60 and then you have the longer purple with its extended housing that's 80 psi. All cast oil pump housing are the same.
GTO GEORGE
