Old 09-15-2017, 07:10 PM
Simple Man's Avatar
Default Torque converter drainback
If I let my 68 GTO sit more than a couple of weeks, I'm greeted with a sizable puddle of ATF under it. I'm told this is ATF draining back into the converter. Any solution to this, other than driving it more?
be a simple...kinda man.
Old 09-15-2017, 08:56 PM
1969GiPper 1969GiPper is offline
It shouldn't be leaking anything. My 69 G/P does the same thing. I've swapped out the torque converter and the converter to front pump seal twice. Still leaks. I figure it's either the front pump to trans case gasket/seal or the pump or case have a sand hole (porosity).
Old 11-13-2017, 11:22 PM
Could be wear at the front pump bushing, not a expert but did stay at a Holiday Inn once.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 11-14-2017, 12:56 PM
oldgoat455's Avatar
oldgoat455 oldgoat455 is offline
I am no expert at this either, however had the same problem with my 68 a few years back. Huge puddle underneath after sitting for the winter. My buddy told me it's leaking around the dipstick seal. I replaced mine and sure enough, that took care of the problem. Hope this helps.
