Old 10-06-2017, 08:46 AM
Tiger Paw Tiger Paw is offline
I would think anybody using heavier viscosity oil should use a heater. Especially when air temp is low. We ran a large heat pad on the oil tank and a smallish pad on the pan. My Comp engine used 5-20w and was fastest with oil at 170-180° and coolant at 140° at launch.
This was in 2000-2003, with specific clearances and spun up to 9200. If this doesn't apply to your program, use what works for you.
Old 10-06-2017, 09:46 AM
Thank You Sirrotica and Tiger Paw for your additional VALUABLE information added to this thread.
Old 10-06-2017, 09:57 AM
Stan Weiss's Avatar
I do not know about Mike and Eric's engine. But on some all aluminum engines running a tight lash cam in very cold weather you need to preheat the engine just so you are able to start it because of negative valve lash.
Stan
Pontiac Pump Gas List
Old 10-06-2017, 11:34 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
I have a question for Mike and Eric....A lot of The injected Nitro dragsters run cold fuel and when I say cold I mean below 0ish degrees Fahrenheit......do you guys run cold fuel on the boss bird?
We have done a bit of experimenting with Alcohol in the past with the pro mods with decent results.
Just wondering if you guys have with your nitro motor.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 10-06-2017, 11:44 AM
Good Question, looking forward to reading about that side of it.
Old 10-06-2017, 12:58 PM
I'm guessing they probably run more of a straight 70w oil.. Possibly Brad Penn if its still available..
Do you guys change your oil after a warm up in the pits Eric? I know it can get very diluted with fuel inveryshort order.. I actually used to save my old deluted oil in a vented and filtered drum and let the alcohol evaporate off... Running on a shoe string budget, it was nessasary..lol ran the same main bearings for 2 years..only issue I ever had was the plugger oil pump giving up on a start up.. We ran around 140psi..with .005 clearances on the mains and .oo4 on the rods.
Old 10-06-2017, 02:05 PM
Great Post, Thanks Scott for the additional info.
How long did it take for the alcohol to evaporate off?
Old 10-08-2017, 09:53 AM
Race Day, Race Day, Race Day! Put down some BIG NUMBERS Mike and Eric!
Have fun too!
