Old 11-01-2017, 09:21 PM
charlie66's Avatar
Default Bottom Feed Turbo Intake Build
I started making the pieces for my Intake . So far I made a die for making the runners. I searched all over the internet for the right size runner material with no luck, so I decided to make them.. The die took me a couple of weeks to make but it was worth it. I got one runner made so far , it wasn't that hard once I figured out how to go though the process of lining it up square with the right size of aluminum needed so in the end of the pressing process it butted up with a small gap for welding . Im also in the process of making the head and plenum flanges as well as the throttle body flange. Im trying to figure out a way to O-ring the plenum flange with a bolt on feature so just in case the plenum I designed doesn't work I can just unbolt it and only have to build a new plenum instead of the whole manifold . Here are some pictures of the die and a runner I made with it. Also is a couple of the big chunk of aluminum im making the flanges with . It started out at 6"x28"x2" . I cut it down the middle making it basically a 6"x28"x 7/8" piece. Soon it will take shape to the size it needs to be... Its a lot of work though..
ID:	466688   Click image for larger version
ID:	466689   Click image for larger version
ID:	466690   Click image for larger version
ID:	466691   Click image for larger version
My Half AN Injun.....
Old 11-01-2017, 09:24 PM
charlie66's Avatar
More
ID:	466693   Click image for larger version
ID:	466694   Click image for larger version
ID:	466695   Click image for larger version
ID:	466696   Click image for larger version
Old 11-01-2017, 09:25 PM
charlie66's Avatar
more...
ID:	466698   Click image for larger version
ID:	466699   Click image for larger version
ID:	466700   Click image for larger version
The Following User Says Thank You to charlie66 For This Useful Post:
Old 11-01-2017, 10:07 PM
Looking Good Charlie.
That is the way I have seen McLaren Fabricators built intake runners.
Difference is they laid out lines on the material and formed a series of small bends to get a bigger radius bend for each corner of the runner 1/2 shell.
Old 11-01-2017, 10:50 PM
charlie66's Avatar
Thanks Tom...
Old 11-01-2017, 10:52 PM
charlie66's Avatar
This is 3/16" plate. Should hold high boost pretty well...
Old 11-01-2017, 11:30 PM
73 TRANSAM 73 TRANSAM is offline
Charlie, looks like you started fabricating your intake. Looking good!
Old 11-01-2017, 11:32 PM
73rekventura 73rekventura is offline
Nice job on the die to make the runners! This will be interesting to see what this manifold looks like when done.. ..
Never heard of a bottom fed manifold before...
Old 11-01-2017, 11:35 PM
charlie66's Avatar
Thanks Edwin .. Its going to be a winter project..
Hope it works.. lol
Old 11-01-2017, 11:38 PM
charlie66's Avatar
Thank you..
Yeah its for better distribution of the air..
Will it actually work that way.. I don't know, but im going to find out.. haha
Old 11-04-2017, 07:39 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Nice !!
Keep us posted on the progress.
Old 11-29-2017, 09:21 PM
Can we BUY intake flanges?
Old 11-29-2017, 09:30 PM
charlie66's Avatar
I haven't seen any that's why im making my own.. Same goes with runner tubing. Haven't seen those either so I just made them ..
Old 11-29-2017, 09:58 PM
wreckmastr's Avatar
Mopar but same thing really
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 11-30-2017, 08:02 AM
charlie66's Avatar
Hey Billy, Do you know much about this car? I wonder how wide the slot is feeding that plenum? That's the same idea I had for my 8 cylinder build I doing..
Thanks for posting this . I've been looking for pictures like this with this design ..
Got any others or different angles of this one? We all know you're the king of pictures ! Hahaha...
Old 11-30-2017, 08:23 AM
Billy, they did a really nice job on that "Bottom Feed" Intake. Whole package should be "Bad to the Bone". What Kind of times was the car running?
ps Charlie, We did testing on the "Slot" on a Audi Manifold designed in production with the slot.
The Audi intake was adapted to our 4 cylinder engine. Mixed results (if it did anything better, it did not show up on the dyno) vs the simple "bottom feed bounce off the roof" design by Mahovitz.
ID:	468996   Click image for larger version
Name:	Audi Slot Manifold.jpg
ID:	468999   Click image for larger version
Name:	Auto Cad Image AUDI Intake Design.jpg
Old 11-30-2017, 08:39 AM
One of the absolute best Center feed Intake manifolds ever designed. Wally Beaber did this design. Air comes in, bangs off the wall and perfect distribution to the 8 runners.
Same would apply to a 4 cylinder (or 8 cylinder) "Bottom Feed" intake feeding 4 (or 8) cylinders.
John Mahovitz was not stupid and neither was Wally Beaber. The Audi Slot never showed any real gain over the side feed and bottom feed design, if anything it was worse as the slot width dimension and length was critical to get even close to the Beaber manifold.
Old 11-30-2017, 10:36 AM
wreckmastr's Avatar
It's Jason Digbys Dodge dart That Lyle Barnett drives in Outlaw 275. I'll see if I can dig up some more pics of it for you.
To date Its been 4.17 @ 191 Check out the video of the steup
https://www.youtube.com/watch?v=KCD9mk3ExwA
6.98 @ 199mph
4.53 @ 164mph
Old 11-30-2017, 04:52 PM
charlie66's Avatar
Thanks Tom. I like the second picture . Would like to know more about that one..
Old 11-30-2017, 04:53 PM
charlie66's Avatar
Thanks !
