EFI Tech All things EFI and making classics modern!
Old 12-16-2017, 12:30 PM
Interceptor's Avatar
Interceptor Interceptor is offline
Default 455 Intake for EFI
Planning to install Sniper EFI under a 70 TA shaker hood. Stock rebuilt 1975 455 with 6H-6 heads so thinking a Voodoo 704 cam & lifters.
From all my searches I see that the Performer intake will be mediocre at best. Most threads turn into drag-race discussions. What street intake do y'all suggest to fit the square-bore Holley?
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-16-2017, 12:56 PM
Holley Street Dominator (They are still out there) (new in some cases) along with your Holley Carb Clone EFI system. You know that will package with a Shaker.
Old 12-16-2017, 12:59 PM
JLMounce JLMounce is offline
I am running a torker II on my street 455 with the FiTech. Previous to that I had a P4B on there and I had some fuel distribution issues with the throttle body injection and that specific dual plane manifold. This intake has worked really well with the combination. it makes gobs of power from off idle to 5700 rpm in my combination.
One of the very first posts in the big FiTech thread discusses hogging out the plenum on a factory intake to fit the square bore, which would also be an option for you.
One thing to also keep in mind is that Holley does sell a bottom portion of a drop base air cleaner with provisions to clear the fuel inlet/outlet on the tbi. That will give you a bit more room with the shaker.
-Jason
1969 Pontiac Firebird
Old 12-16-2017, 01:09 PM
Tim Corcoran's Avatar
The Tomahawk manifold or the Holley Street Dominator as Tom says. Both work well with a stock or slightly modified engine and a Holley square bore carb. The Holley street dominator has rather small runners that provide good velocity for a close to stock combo but with big cam, big cubes and ported heads it would need some port work. The Tomahawk was patterned after the Holley manifold but flows more air for a modified engine.
Tim Corcoran
Old 12-16-2017, 02:11 PM
Can't find any, not even on Fleabay. How about the Torker 2 mentioned below? Listed as only 0.400" taller than stock, but Summit Notes says it wont fit with a shaker.
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-16-2017, 02:12 PM
Taller, not?
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-16-2017, 02:29 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
Was a HSD in the classifieds last week. I mean there is one http://forums.maxperformanceinc.com/...d.php?t=812697
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
Old 12-16-2017, 02:41 PM
maxpowerta maxpowerta is offline
This is the tomahawk on a 76 T/A it's not too tall.
Old 12-16-2017, 04:41 PM
Larry Navarro's Avatar
I haven't checked as I don't have EFI yet but hopefully my shaker setup will adapt with the EFI throttle body using the taller RPM or Tomahawk.
Old 12-16-2017, 09:15 PM
wh33lman's Avatar
wh33lman wh33lman is offline
Thought you may be interested in this post...
http://www.modsandrods.tv/2015/08/25...ject-trans-am/
Old 12-16-2017, 09:39 PM
ta-69's Avatar
ta-69 ta-69 is offline
I have a HSD I'd sell for 125. Plus shipping
Old 12-17-2017, 10:42 AM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
I modified a SR 72 455 HO intake. Factory parts fit perfectly.
Old 12-17-2017, 11:36 AM
Well, there we go. Simple. How did your factory linkages hook up?
Is the factory 1975 intake any good? What is the diff between it and the popular 1972 intake?
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-17-2017, 11:37 AM
I'll think about that, thanks. Condition?
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-17-2017, 11:46 AM
The 75 intake will be cast iron and will be harder longer to grind on, and it also has the EGR hole. I bought the NOS 72 service replacement intake for $400 so it was a no brainer to go factory parts. Haven't gotten around to hooking up the linkage yet.
ID:	470270   Click image for larger version
Old 12-17-2017, 12:01 PM
Well, please keep us posted.
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-17-2017, 07:20 PM
Lee's Avatar
Lee Lee is offline
If you are not in a rush to get the intake, then maybe wait a bit.
I'm hoping to have the FAST EFI system up and running on my '73 T/A clone by the end of next month. Once I've got it running properly, I'm hoping to borrow a few intakes and do some chassis dyno testing.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 12-17-2017, 07:31 PM
Looking at the "yahooskidoo" photo above, I doubt my shaker assembly will adapt. The throttle body has the "outboard" components that would clash with WFO dropped base design.
Old 12-20-2017, 12:15 PM
00fxd 00fxd is offline
There has been some testing done recently that indicated that single plane works better with EFI. You might want to research that.
Old 12-20-2017, 12:48 PM
Steve C. Steve C. is offline
Was the study with direct port fuel injection with injectors to each intake valve or Single-point that just replaces the carb ? Or both types ?
Old information here:
