Old 01-17-2018, 09:22 AM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
"My side" of the LeMans is dismantled, wire brushed, primer paint. Ready to begin assembly tomorrow! STOKED!!...
I just might be getting the hang of this....Time will tell...and how the 1/4 fits will tell.....
ID:	472764   Click image for larger version
ID:	472765   Click image for larger version
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
  #222
Old 01-17-2018, 09:43 AM
Have fun...I actually enjoy tossing rusty metal out and welding new stuff in...as long as it fits. It's like building a big ol' 1:1 scale model!
Old 01-18-2018, 07:51 AM
Kurt L71S's Avatar
Clark says, "Passenger side is yours". 5 hrs yesterday, 3 hrs today....getting closer to welding in place. Might get in some welding time tomorrow! She's once again looking like a LeMans Sport....
1st photo is before I got started with the air chisel....BTW this is the exact method Tim Taylor would have used!...More Power....UH, UH, UH!!!...
ID:	472831   Click image for larger version
ID:	472832   Click image for larger version
ID:	472833   Click image for larger version
ID:	472834   Click image for larger version
  #224
Old 01-18-2018, 07:04 PM
2002Z4CSS's Avatar
Looking great ! I will be doing the same soon.
ID:	472893   Click image for larger version
ID:	472895   Click image for larger version
1971 Pontiac GT-37
  #225
Old 01-19-2018, 08:09 AM
Kurt L71S's Avatar
Z4,
That looks rather familiar! Good luck with your build. There is a lot to be said for doing some of it yourself...Nice to be able to talk intelligently about it...
Keep up the great work....
  #226
Old 01-19-2018, 08:26 AM
Kurt L71S's Avatar
Rear Shelf time...Funny...this is the first replacement and the only part (so I thought) that I purchased for this car!...
What makes this restoration so much fun for me are the tools....Air Chisel, Cutoff Tools, Air Grinder....Uh, Uh, Uh....More Power!!!...
These are not the easiest pieces to replace. One needs to proceed with care as not to ruin the sub structure that the shelf relies upon. This is the same structure that the trunk hinges and spring are housed on....
Not too bad underneath...Nothing that some Rust Restorer won't take care of...
ID:	472978   Click image for larger version
ID:	472979   Click image for larger version
ID:	472980   Click image for larger version
ID:	472981   Click image for larger version
  #227
Old 01-19-2018, 03:50 PM
2002Z4CSS's Avatar
Originally Posted by Kurt L71S View Post
Z4,
Thanks, it's all the motivation that keeps projects moving forward.
1971 Pontiac GT-37
  #228
Old 01-19-2018, 06:17 PM
Kurt L71S's Avatar
I had another productive day at Basic Body and Paint. I had not a clue just how tough removing and installing the back shelf on a car was! I'm not real sure I can get anymore STOKED than I am right now. Can hardly wait to do some practice welding and install these panels for good....
Rear section between the trunk and the glass is drilled and punched....
Rear Quarters and punched for spot welding into their permanent home...
WOW! for a first fitting...not too shabby...for an old retired hack....
ID:	473010   Click image for larger version
ID:	473011   Click image for larger version
ID:	473012   Click image for larger version
ID:	473013   Click image for larger version
  #229
Old 01-24-2018, 08:22 PM
Kurt L71S's Avatar
We set the trunk lid in place yesterday! Fit and welded the rear deck shelf into place...
WOW! The gaps on the rear quarters are amazing! Especially when you are working with someone that knows the business. This is not his first rodeo!...
Test fit the bumper before any welding was done. Need to make sure we had enough adjustments on the bumper bracing to make her fit like a glove....a new glove, I might add. As you can tell, there is enough wiggle room to pull her up tight!...
ID:	473533   Click image for larger version
ID:	473534   Click image for larger version
  #230
Old 01-24-2018, 10:48 PM
tjs72lemans tjs72lemans is offline
Looks good. That looks worth getting excited about!!
  #231
Old 01-25-2018, 03:21 AM
Shiny Shiny is offline
Agree..
I have zero experience, but everything I have read here makes me think you achieved alignment miracles. Impressive!
  #232
Old 01-25-2018, 07:42 AM
Kurt L71S's Avatar
TJS,
Excited is an understatement! I have been stoked about the is build from Day 1...
Thanks for looking and your comments as well....
  #233
Old 01-25-2018, 07:47 AM
Kurt L71S's Avatar
Agree..
Shiny,
For not being OEM sheet metal, these two rear quarters, inner & outer wheel houses along with the trunk panels have fit very well. I am so excited to get them welding into place and begin cleaning and prepping the doors and front fenders....
Progress for sure!...
  #234
Old 01-30-2018, 09:27 AM
Kurt L71S's Avatar
Have the trunk welding into place and smoothed the welds. I worked with the DA Sander and now have her ready for Etching Primer, Seam Sealer, and her final coat of Trunk Spatter Paint...
Outer Wheel House is in place along with the Trunk Floor Drop Off Fillers..
ID:	474032   Click image for larger version
ID:	474033   Click image for larger version
ID:	474034   Click image for larger version
  #235
Old 01-31-2018, 09:26 PM
Nice work. Looks like great progress.
  #236
Old 01-31-2018, 10:56 PM
2002Z4CSS's Avatar
Looking good !
1971 Pontiac GT-37
  #237
Old 02-01-2018, 08:57 AM
Kurt L71S's Avatar
Had some wonderful news yesterday as I "uncovered" my right front fender...
Solid from one end to the other!...
These fenders are like hen's teeth! Try to find one or for that matter, a pair in this condition...
Need to do a little work on the drivers side fender. Not a problem! At least I don't have to find "new" ones....not real sure they are out there....
ID:	474255   Click image for larger version
  #238
Old 02-02-2018, 12:00 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Man Kurt, you’re gonna have a show stopper there pretty soon! Keep up the good work and updates!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
  #239
Old 02-02-2018, 03:08 PM
Kurt L71S's Avatar
Oh WOW Eric!! I can only imagine just how cool this 71 LeMans Sport is going to be!...
I am to the point where I can hardly wait for another day to work on her. I hope her name "Blu BiYu" will live up to it's name! I should have named her "Blu Yr Mind"...
Thanks againg for your kind words Eric....
  #240
Old 02-05-2018, 08:15 PM
2002Z4CSS's Avatar
You will be done before you know it. Once it is you, will have a greater sence of appreciation for the Lemans. Since your doing the work. I am having the same feelings. Can't wait to drive my car again !!!!
1971 Pontiac GT-37
