Old 02-07-2018, 07:08 PM
64speed's Avatar
64speed 64speed is offline
Default Project Phoenix, a 1964 Tempest rising from the ashes
Well this is my first time starting a thread so we will see how it goes. Basically I bought this 64 Tempest for 2500 and sold the Tri Power that the guy put on it for 2600 so I started out with nothing in the car. The car had been hit hard in the drivers side rear and had caked on bondo and a quarter skin pop riveted on. I took the car to AMD and they replaced everything from the doors back. I had to source a tail panel from a donor car and the trunk lid still needs work because it is bowed from the impact. I plan to build a 467 using one of the two 455 blocks I have. It will have edelbrock round port heads and Paul Carter has already spec'd a Lunati HFT cam for me that I purchased. I dont have the cam card in front of me so I dont know the specs. I am overbuilding it because I do not want to do it twice. This car will be my regular driver and I want zero problems. I plan on installing a T56 Magnum from SST in place of the original two speed transmission. I have a steering column from ididit so the floor shift will look appropriate. The car will be silver mist grey on the outside and nocturne blue on the interior. I am retaining the bench seat. I have wilwood brakes for the front and I am running a ford 9 inch with explorer disc brakes on the rear. It has 3.70 gears and a detroit true trac limited slip. I will post updates as they occur. Right now I am getting estimates on body work.
ID:	474903   Click image for larger version
ID:	474904   Click image for larger version
ID:	474905   Click image for larger version
ID:	474906   Click image for larger version
The Following User Says Thank You to 64speed For This Useful Post:
Old 02-07-2018, 07:12 PM
64speed's Avatar
I plan to have the original radio converted to bluetooth so I had to patch the dash where the previous owner had butchered it. Wheels are 18x8 US Mags.
ID:	474908   Click image for larger version
Old 02-08-2018, 07:39 AM
The Champ's Avatar
What do you mean?
This is the 157th thread you've started in just the last 6 months.
The Following User Says Thank You to The Champ For This Useful Post:
Old 02-08-2018, 10:24 AM
64speed's Avatar
I thought there was a difference between a post and a thread
Old 02-08-2018, 10:43 AM
78w72 78w72 is online now
technically "i think" a post is something you or others do in a thread. its a thread of posts...
this could be considered your first thread specifically about your projects build that you will update with posts about actual progress made instead of just general questions.
good luck on your project though, looks like a lot of work ahead.
Old 02-08-2018, 11:08 AM
1968GTO421's Avatar
Will be staying tuned to your thread to see how things are going. Best of luck!!!
GTOAA--https://www.gtoaa.org/
Old 02-08-2018, 11:30 AM
Congrats on your first thread.
Hopefully the car will progress along nicely now that you have some of the basic bodywork at least in place.
Unless the frame came out of California, there is always room for work there.
Believe you had a shop working on that part of the rerstoration.
Do you have pictures of the frame work?
I have two 64 "GTO"s, a clone drag car and a original Tri-Power 4 speed convertible. I had Scott Tieman do the frame swap on the Convertible so I have no pics of that work done. That is why I asked about your frame and pictures. Always nice to have more under-carriage pictures.
Thanks for the Thread.
Old 02-08-2018, 02:24 PM
Congrats! Looks like it's coming along nicely...but I have to say...you have definitely started some threads. I've read quite a few of them.
In fact, there are FOUR threads started by you on the Body Shop forum right now and that's just on the front page.....lol
I'm pulling for you though man. Keep choppin' wood as they say.
Old 02-08-2018, 02:49 PM
77 TRASHCAN's Avatar
Looking forward to updates!
Shut it off
Shut it off
Old 02-08-2018, 05:50 PM
64speed's Avatar
Here is the only pictures of the frame I have. It was straightened in a jig. Also I forgot to mention I am running the complete Holley Sniper fuel system from fuel tank to EFI unit
ID:	474973   Click image for larger version
Old 02-09-2018, 08:34 AM
The Champ's Avatar
There definitely is.
This was your 157th thread that you've started in the last 6 months. That means you've originated a thread 157 times in just 184 days - almost a daily occurrence.
You've most likely had thousands of posts in the same time period.
Good luck on your project.
Old 02-09-2018, 09:18 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Love to see a car saved ...and one of my favorite body styles. Long road ahead but you have a plan and vision.
Definitely keep the updates coming ...
Old 02-09-2018, 10:17 AM
Firebob's Avatar
Firebob Firebob is offline
Good on you for building something that others would've thrown away. Always nice to see something done that you've never seen before. I have to wonder about a 467 in a DD though. Sounds like it's going to be a handful.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 02-09-2018, 10:59 AM
1968GTO421's Avatar
I am sure you have seen of the the build threads on the forum from other members to get some ideas. One of my favorite build threads is about a GTO. The thread was started in 2013 and is almost finished. I've really enjoyed it over the years. Here's the link
http://www.gtoforum.com/f83/dans-69-restore-tale-53945/
Old 02-09-2018, 05:33 PM
64speed's Avatar
It’s gonna be a powerhouse but I have plenty of interstate and highways around me. I am not building it too radical. I don’t have the crank for the 455 so I might as well buy a stroker
Old 02-09-2018, 07:14 PM
64speed's Avatar
One thing AMD did to me that I did not like was left out two body bushings and just handed them to me when I picked the car up with a picture of how they needed to be modified and said have at it. Apparently the body bushings under each door in the front were too tall and they couldnt get thread engagement. I contacted Ames and they said that shouldnt be and that all the bushings were the same but nonetheless I took AMD word for it. After consulting a local bodyshop and them telling me it would be at least 200 bucks if not more I called AMD back and asked them just what the hell was I supposed to do with these bushings, they took it off the frame they should put it back. Again they referred me to the picture and told me to just cut about a 1/4 of an inch of the top bushing and I would be good to go. I am terrified of body work because I know nothing about it. Anyway I got out a fresh box cutter and using painters tape I took about a quarter of and inch off both bushings. I went outside. Took everything loose but not off, slid the bushings in and bolted them down. Took less than 30 minutes. So thats done and I am proud of myself.
Old 02-09-2018, 07:41 PM
imposter's Avatar
imposter imposter is offline
nice project, nothing beats a post car, good luck
Old 02-09-2018, 07:55 PM
Will Will is offline
Torquewar beat me to it.
One of my all-time favorite bodies and you're bringing it back from the dead.
Keep up the good work!
Old 02-10-2018, 12:19 PM
64speed's Avatar
OK I see where the cable actually goes thru the firewall but the end of my parking cable and the actual clevis on the pedal are a mile apart and I cant pull the cable out. How do I get it attached?
Old 02-10-2018, 12:24 PM
64speed's Avatar
ok I got it.
