Old 03-07-2018, 03:31 AM
dataway's Avatar
dataway dataway is offline
Yep, that does look like a nice piece there, probably worth every penny.
Old 01-05-2019, 07:14 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
So a year later & I went to install my TSM heater core & its not as thick as the original. Never noticed that until installing it. What did you guys do? This is in a Non-A/C car.
Thanks! 68RT
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 01-06-2019, 01:58 PM
1968GTO421's Avatar
MD79TA posted the measurements of his Ames/TSM heater core. If yours is the same size as his I would surmise that it will fir OK since MD79Y never posted a complaint that it didn't fit OK and most folks complain on here if a part doesn't fit right.
After reading Bobalong's description of the job he had to do to replace the core, if mine goes out, I may just drain it and loop the heater hose from the engine back into the engine. (Did that with another car and it worked well. However, I do live in a warmer state than you. It's 67* right now.)
Best of luck with a difficult job. Hopefully someone who has used a core like yours will chime in on actual results.
GTOAA--https://www.gtoaa.org/
Old 01-06-2019, 11:10 PM
68ragtop's Avatar
Got it figured out. I ended up fabricating some nylon spacers on both ends to compensate for the lack of thickness. MD79's core looks like its as thick as the original, but his is an A/C car, so it could have something to do with that. The box has been out of the car for many years & finally going back in, so it was no trouble getting to it.
89 Trans am GTA
Old 01-07-2019, 12:50 PM
1968GTO421's Avatar
^ Nice work
