Old 03-10-2018, 10:04 AM
jimib's Avatar
jimib jimib is offline
Originally Posted by Jeff Hamlin View Post
The good thing about the composite tack strip is you could use it without the factory metal retaining channel.
It is dense enough to be screwed onto the body as is and it holds staples very well.
May take a few extra screws but could be done.
I think 2 strips aprox 1/4" X 3/4" would work well for these.
If I make it over to the shop later I'll measure the strips off the '66 project to give you a better idea of a size.
If you get chance to take that measurement Jeff, I can get a jump start on ordering this tack strip. I won’t have chance to undo my work and measure the existing metal retaining strip till next week.
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 03-11-2018, 07:21 PM
Jeff Hamlin's Avatar
jim,
regrettably didn't locate any tack strips for the current '66 in the shop.
Since the car came stripped it's likely we'll also need them.
Sorry.
Old 03-12-2018, 02:00 PM
jimib's Avatar
Smile
jim,
Sorry.
No problem Jeff; thanks for trying. I'll get this figured out. (-:
Old 03-30-2018, 04:04 PM
jimib's Avatar
I installed my tacking strip from www.bobdrake.com. I used the 3/16 x ½ strip and trimmed with a razor scrapper to make it fit within the metal strip grove. I then used 3M Weather Strip Adhesive to glue (dries really strong) the strip to the metal strip and clamps to force it into the metal grove. I may fabricate a 2nd strip and install beneath the original.
May be a week or two before I restart the headliner/sail panel install.
Old 04-08-2018, 04:59 PM
jimib's Avatar
Here’s my 2nd attempt at installing the headliner/sail panels; doesn’t look much better than the 1st. It looks very amateur in the back section. I spent hours trying to get the wrinkles out. The pic's of the front headliner are hard to see.
This is the best I can do and I’m going with it. I want my ground-up resto done by years end.
ID:	480218   Click image for larger version
ID:	480219   Click image for larger version
ID:	480220   Click image for larger version
Old 05-30-2026, 03:12 PM
Indy1k Indy1k is offline
I dont know if this will help anyone as this original post was 8 years ago, but some of us are revisiting this issue.
I am unable to locate new or repop Headliner Tack Strips too.
I thought I would post the pictures with the measurements of the tack strip and the end showing the material slid inside.
I will order new material for mine from https://jjautofabrics.com/tack-strip...ontinuous-yard, 0nly $6.10 a yard
I will gut the metal channel and put the new material in.
Hope this helps.
Kevin
65G GTO, Hrdtp, 428, tri-power, M-20, 4:11 posi, power disk up front and factory air!
