Old 03-27-2018, 07:57 AM
77 Canamman's Avatar
This "journey" pales in comparison to yours, Bob. However, I have spent hours studying several TSB's and Hurst manuals from the day. It helps having a complete roof sitting at my disposal. I am confident this will go well. Even with purchasing the complete roof, all new weatherstrip, the trunk storage bag, clips, bolts, and various parts/supplies, I have spent less than $1500.
I will follow your advice on the tape. The original paint on this car is excellent, so I will do everything possible to prevent damage.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #122
Old 03-31-2018, 10:41 PM
Thumbs up
Drivers side is cut. I did not encounter any paint chipping. I cut it right the first time. The frame set right into place. The support slipped right in between the roof panels. Off to a good start..
ID:	479587   Click image for larger version
ID:	479588   Click image for larger version
  #123
Old 03-31-2018, 10:48 PM
Neat work, likely neater than when done on rushed production line. Now get out and cruise in your rare Half-Hurst!
How did you end up trimming it, dremel or similar rotary saw?
  #124
Old 03-31-2018, 10:59 PM
I used a battery operated jig-saw. A saws-all was used for a couple of the initial cuts.
  #125
Old 04-01-2018, 09:07 AM
The Boss's Avatar
The Boss The Boss is offline
Only for the brave!
Well done!
And go racin' in the street.
  #126
Old 04-01-2018, 11:19 AM
Poncho Dave Poncho Dave is offline
Looking good!
  #127
Old 04-13-2018, 08:00 AM
I found this nOS beauty..
  #128
Old 04-13-2018, 10:20 PM
Talking
Other side done. Absolutely zero hiccups. The frame fit great. Now to refinish the tops themselves, and reassemble the headliner, and various trim.
  #129
Old 04-13-2018, 10:36 PM
ladytata's Avatar
ladytata ladytata is offline
Trashman that looks bad as$, congrats on one hell of a job! Looks awesome.
  #130
Old 04-14-2018, 07:48 AM
Thank you, Teri.
  #131
Old 04-15-2018, 11:52 AM
TAKerry TAKerry is offline
WOW! My hats off to you. Great job. I would never have even considered attempting that on a finished car. What do you have to do to "refinish the tops"?
I have a few pair that need some work and would like to see what you do.
  #132
Old 04-15-2018, 12:15 PM
Lightbulb
Thank you, Kerry.
I figured that Hurst performed this surgery to several thousand finished cars back in 1976-1978, so why not?
The tops I have have good glass, but the frames were painted rather poorly in black. I will strip this paint off, use a high quality etching primer, and paint them trim black. If this does not hold up, then I will have to locate factory black anodized tops. I intend to have the tops in the trunk the majority of the time I have the car out.
  #133
Old 04-16-2018, 12:48 AM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Great thread........Think I've gone through most of it....
.Don't think I could pull the sawzall trigger .....on a TA of that caliber.
Just wondering if your 77 has the original bumper jack...(I'm sure it does)....and would you have some pics of it to post?
I think I have the right one...but need to confirm...
Old 04-16-2018, 09:04 AM
Wink
Thanks, GH
The jack equipment has never been removed from its location since the cars assembly. The tire has never been on the ground. I will shoot a better photo of it for you this evening.
Here are the two I currently have on file:
ID:	480768   Click image for larger version
  #135
Old 04-16-2018, 05:31 PM
Arrow
The jack and handle:
The RH side. The Metro weatherstrip has been installed. LH side already completed. The headliner is in and trimmed.
ID:	480800   Click image for larger version
ID:	480801   Click image for larger version
  #136
Old 04-17-2018, 01:03 AM
Thanks for posting the jack pics....
Can you tell me if the one I have...is the same?
This one is just over 31" long.....and does fit in the brackets....
ID:	480823   Click image for larger version
  #137
Old 04-17-2018, 07:19 AM
The Boss's Avatar
What was involved in trimming the headliner? Was it as simple as cutting and tucking into a trim piece?
I get that Hurst cut a ton of these when they were new, but I'd have probably left the job to my body guy - you are a brave and talented guy!
  #138
Old 04-17-2018, 07:40 AM
Save your money, just use the roof cuts instead of buying t-top glass!
  #139
Old 04-17-2018, 07:43 AM
I installed the headliner. Before the weatherstripping was installed, I marked the opening with a marker, then with an ultra sharp knife, I cut out the headliner. On a first design Hurst Hatch, there is a huge lip on the interior side of the weatherstripping that covers the opening. The headliner is attached to the T Top frames using several small metal spring clips. I have done paint and body jobs for years. I just kept pretending this car was a Sunbird while I took the saws to it. Made it a lot easier.
  #140
Old 04-17-2018, 09:11 AM
Lightbulb
From another board members '78:
Then you'll need the handle, wing nut and retainer.
