Old 07-10-2018, 04:02 PM
Ron Landis's Avatar
Exclamation Wanted....
A good 389 block for a ‘65 GTO....stick car but looking at everything right now. Short block or long block in good re.buildable condition. Thanks in advance!
Old 07-10-2018, 10:03 PM
Goatboyjohnny Goatboyjohnny is offline
https://akroncanton.craigslist.org/p...606751990.html
Not sure if you saw this. Don't know anything about it, but saw your post & remembered the add. Worth a shot I suppose. Good luck.
Old 07-11-2018, 05:50 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
400 piston, so must be .060
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 07-11-2018, 06:46 AM
Good eye John!
Old 07-11-2018, 07:15 AM
goatless's Avatar
goatless goatless is offline
I've got a mostly complete '65 389 down in the garage. It was running in a friend's '65 GTO before I got it. Are you looking for any certain codes? I don't think it's a "GTO" motor, haven't looked at it in a long time.
1966 GTO
Old 07-12-2018, 08:14 PM
Ron Landis's Avatar
Default Odd!
Post was already deleted but if it was the 65 WT short block for $1500...I bought it, I believe that you just solved the puzzle! It looks fresh but pistons sat “standard”...so they are stock 400 units I guess. So...are the valve reliefs gonna work with the 20 degree 65 heads? I know that aftermarket pistons are double fly-cut to work with th e 14 degree heads also. It’s gonna get gone through anyway but I want to do it right. Thanks, guys for your valuable input...it is greatly appreciated!
Old 07-12-2018, 08:43 PM
tom s tom s is offline
Ron,keep the lift down or fly cut them in the block.Tom
Old 07-12-2018, 10:06 PM
Ron Landis's Avatar
Thumbs up Ok....
We’re going roller cam and wanted enough lift to attain a nice exhaust note... but I can accomplish that with duration and lobe separation. Thanks again!
Old 07-12-2018, 10:41 PM
Yes it was the one for 1500.. That's awesome you were able to get it Ron! Good luck with the rest of the build, and keep us posted on the progress!
Johnny
Old 07-13-2018, 03:25 AM
FASTASSBIRD FASTASSBIRD is offline
I got a 65 WT short block for 1500 if anyone else needs one
Old 07-13-2018, 08:48 AM
Ron Landis's Avatar
Default So...
Where are you located?
Old 07-13-2018, 01:48 PM
I am in central California, I know a really good and reasonable shipper I can put you in contact with. He drives by my house frequently and travels all over. I can tell you his rates are ridiculously reasonable
559-321-4096
Old 07-25-2018, 04:15 PM
Ron Landis's Avatar
Default Thanks....
The one we got is decent...recently rebuilt just had the wrong pistons. Who sells a good 389 piston with @ 9.5 : 1 compression with stock heads?
Old 07-25-2018, 08:14 PM
Cardo's Avatar
Cardo Cardo is offline
Building my 389 right now. Icon makes one that may be a possibility. Butler and Kauffman handle those. Otherwise, you'll probably end up going Ross custom forged. That's the route i'll need to go.
