Old 07-18-2018, 07:14 PM
Formulabruce's Avatar
Default 1970 ONLY part , Is Your car correct?
The 1970 Subframe, aside from some welding differences with the 71's etc, are different on the bottom. Have checked this on Norwood and CA cars and verified it to be correct. I assume there are Plenty of restored 1970 Birds with the "wrong" year Subframe. Its a ton of work to replace one on a done car, and most will say, who cares?. Its JUST Information...
FWIW .. Repaired cars could have a newer subframe from a dealer even. Note the "frame shop welders or equipment actually Sucked IMHO.
ID:	488273   Click image for larger version
Old 07-18-2018, 09:47 PM
FunctionalShaker FunctionalShaker is offline
Verified, both of mine are correct.
Old 07-18-2018, 10:00 PM
I have a 6 24 70 dated frame that is like the one you have labeled "71-74". It came from a '70 Esprit. So perhaps it was a late in the model year change....
Old 07-18-2018, 11:15 PM
5D Van Nuys Formula, has the first one pictured.
Old 07-18-2018, 11:28 PM
unruhjonny's Avatar
I'm actually (slowly) stripping my subframe and hope to have it blasted saturday morning;
IIRC there was a thread either earlier this year, or late last year which said that a partial vin was stamped on it - I was going to use that to verify if this is my original subframe (now I just need to find that thread!)...
Yay for a '70 subframe ID!!
1970 Formula 400
Old 07-19-2018, 03:43 AM
Date on the rear DS side of the frame?
The Latest I have verified was a 05D , like the one above.. I assume things changed for the new model year, but not sure when.
Old 07-19-2018, 05:53 AM
Norwood's Avatar
Norwood Norwood is offline
Did a blind guy weld these ?
Old 07-19-2018, 09:15 AM
unruhjonny's Avatar
for the record mine is 06A
1970 Formula 400
Old 07-19-2018, 11:30 AM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
1971 Firebird Esprit with 8,043 original miles.
Name:	1971 Firebird Esprit.jpg
Old 07-19-2018, 11:51 AM
Mines right..
Old 07-19-2018, 11:53 AM
unruhjonny's Avatar
jeeze-louise!?
in fourty-seven years, no-one has really taken the time to enjoy that car!!
1970 Formula 400
