Old 09-02-2018, 10:15 PM
GPMESQ's Avatar
GPMESQ GPMESQ is offline
Default 1969 GTO Bucket Seat Conversion Question
Has anyone converted a 1969 GTO with a bench seat to bucket seats? Do you have to drill holes or are all floorboards predrilled from the factory?
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." Thomas Jefferson
1969 GTO Convertible
1970 Torino GT 429/SCJ
1968 Corvette 427/435hp
1998 Corvette Pace Car
2015 Challenger FF R/T Classic
Old 09-03-2018, 12:32 PM
gtohunter's Avatar
gtohunter gtohunter is offline
You need brackets that are specific to bucket seats....can buy them aftermarket but need to be spot welded to floor pans.
Jimmy M
68 GTO
Old 09-03-2018, 10:00 PM
The outer brackets are the same with buckets and bench (unless power seats are involved) but as mentioned you need to buy inner floor braces ( used or Repro) that will need to be welded to the floor.
Old 09-06-2018, 08:58 AM
gto4evr gto4evr is offline
North, bench seats don't use outer brackets, they just mount through the brace on the front bolt just like the back bolt. Buckets put a little perch bracket welded over the top of the hole and plug the threaded insert with sealer underneath it. so he'll need to weld both inner and outer brackets.
The outer rear bolt mounts the same through the floor pan with no add on bracket.
Name:	seat bracket.png
