Old 10-17-2018, 01:40 PM
JMB36TA's Avatar
JMB36TA JMB36TA is offline
Default Q-jet adjustment
I知 trying to get the fuel and air adjusted on my Q-jet. Judging by the burning eye sensation I知 getting a lean mixture. I知 going to try it with a vacuum gauge instead of by ear. My question is where is the best place to plug it in, ported or manifold vacuum? Or does it really matter?
Old 10-17-2018, 02:18 PM
steve25 steve25 is online now
When at idle with the primary throttle blades open the small about they should be it would be Manifold vacuum you want to monitor.
You really don't need a vacuum gauge as you want to set the idle mixture screws for the fastest rpm you can get ( as in lean ) with auto Trans as when you drop it in gear it will go just a tad rich.
Just remember that with a Carb there will be tweaking that you can idle wise between Summer and winter temps if you want to get things Dead nuts on even where you live!
Is this a stock Cam that the Carb was calibrated for , or a bigger Cam?
Also if you have stock Exh Manifolds make sure that the motor is fully warmed up and confirm that the Exh heat riser flap is open in that one Exh Manifold.
Please post the details of your motor if you would.
Old 10-17-2018, 02:38 PM
JMB36TA's Avatar
Specs are...
Pontiac 400 .030 over @ 9.4:1
Voodoo cam 227/233
Q-jet 7029253 rebuilt with Cliff痴 kit. 71 jets, 44b metering rods, .039 idle tubes, .059 down tubes, .110 idle bypass mod.
I think it just needs fine tuning.
Old 10-17-2018, 05:16 PM
JMB36TA's Avatar
Well this is discouraging. Seems like the F/A adjustment has no effect. I turned them all the way in, and up to over 5 turns out and there's no difference in idle of vacuum. The vacuum bounces between 13 & 15 no matter how I adjust.
Old 10-17-2018, 06:27 PM
george kujanski's Avatar
first thought is you are getting fuel from other than the idle system.
George
Old 10-17-2018, 06:28 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Joe, does the engine try to slow down when you run the A/F screws all the way in? The engine should try to die, or die. If it doesn't, it sounds to me like it is getting idle fuel from the transition slot from the butterflies being open too far at idle to get enough air to idle. You may need to put a small hole in the front butterflies in order to get the butterflies closed enough to not pull fuel from the transition slot.. Cliff or someone else more proficient with Q-jets can correct me if I'm wrong, but that's what it sounds like to me.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-17-2018, 06:38 PM
JMB36TA's Avatar
Hey Paul. I don't notice a difference in the RPMs when I turn the screws all the way in or if I back them way out. There may be a slight difference but I don't have a tach to be certain. I tried to adjust it with the engine at operating temp so the butterflies were open. One thing I read was to cover the front opening with your hand to see if the engine races, mine dies.
Old 10-17-2018, 09:55 PM
455GRIN 455GRIN is offline
Turn the idle down low, and try the mixture screws again
Old 10-18-2018, 12:05 AM
Schurkey Schurkey is offline
Burning-eye exhaust is typically from misfire. Could be lean misfire, could be bad ignition, could be anything that causes misfire.
I run the engine until it's fully warm. Chock the wheels, engage park brake, put it in gear, and then adjust for highest vacuum. I find a vacuum gauge to be more sensitive than a tachometer.
I have a Q-jet with holes in the primaries, apparently done by Rochester. That said, I'd drill holes in the casting to route some idle air around the throttle blades, rather than drilling the blades themselves if possible. Many Q-jets are drill-able for idle air bypass.
Yup.
Old 10-18-2018, 01:21 AM
You may know this but just to be clear, you only partially cover the primary side of the air-horn with your hand. Don't choke it out completely. You're just interrupting the air flow a bit to see if it's rich or lean in the idle circuit.
Old 10-18-2018, 06:15 AM
It sounds like the issue is what Paul said with your throttle blades open too far to get your idle speed so that now your out of stage 1, that being running on the idle circuit and your now running on stage 2, the transistion circuit.
Old 10-18-2018, 10:13 AM
JMB36TA's Avatar
I never thought of misfire. I'll have to look into that.
It has idle bypass. Cliff recommended opening it up to .110 which is where it's at now. Not sure where else I would have to drill to add more.
Old 10-18-2018, 10:33 AM
Need to try this again
Like Greg said, don't choke the engine out. Just start restricitng air flow to see if the engine idles up or idles down.
Also might need to check for more vaccum leaks.
This car got the hot idle compensator on back?
Clay
Old 10-18-2018, 10:38 AM
JMB36TA's Avatar
I got a little confused on your post, you were referring to the throttle blades not the idle blades. I can't see down in there to see if they're open all the way or not, but there are already holes in the blades. I don't see transition holes though. Wouldn't they be above and below the plate in line with the idle screw holes?
ID:	495336   Click image for larger version
Old 10-18-2018, 11:16 AM
JMB36TA's Avatar
Clay
I choked it out but as I slowly covered it I didn't notice any change in idle until I got close enough for it to die.
I've been checking for vacuum leaks over and over and haven't found anymore. All vacuum lines are new. I haven't checked around the carb since I put it back on Monday night so I'll check that again. But I had this problem before I took it off that night.
Yes it has the hot idle compensator. It's off an Olds so it has this little spring and rod sticking out the back. I sealed around it so there's no leaks according to Cliff's instruction. Maybe I should find a new compensator and cover?
Old 10-18-2018, 11:29 AM
Was there parts under the cover? The cover holds the compensator in place.
To run without, the holes in the carb body need plugged.
Also need to find out if those are the right mixture screws. I was thinking 69 used the blunt nose mixture screws, where yours appear to be the long tappered nose. Can't say for sure on that but Cliff or some one else might know.
Clay
Old 10-18-2018, 11:51 AM
JMB36TA's Avatar
Clay
Yes the part was under the cover. I'm 99% sure that I put it back in but now that you mention it I'm going to have to check. There would be no reason that I left it out other than I over looked it.
Don't know about the screws but would they really make a difference?
Old 10-18-2018, 12:02 PM
richardk's Avatar
richardk richardk is offline
It looks like to me you have idle bypass holes drilled in the baseplate and holes in the butterflies. That's a lot of extra air, maybe that's part of the problem?
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 10-18-2018, 12:21 PM
What is that idle bypass mod, the holes in each throttle blade, or .110" holes in the base plate?
If you have both then that's the issue I would say!
Old 10-18-2018, 12:50 PM
I can't remember when the nose shape changed on the screws.
Pretty sure the long tapper screws would bottom out on the spring before cutting idle fuel off. That's if your base plate is suppose to have the blunt nose mixture screws.
Might try taking a spring off to see if the screw will go in further and kill the engine at idle...???
Even with lots of bypass air, should still be able to cut off idle fuel.
Clay
