Old 10-28-2018, 11:30 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Default Water Inlet Tubes
Not mine.
These don't come up very often.
https://www.ebay.com/itm/Pontiac-195...frcectupt=true
Old 10-28-2018, 11:43 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
At some point I'll kick myself for not buying them.
Shouldn't the seller have said '55-''60?
Old 10-28-2018, 11:52 PM
Poncho60 Poncho60 is offline
No reverse cooling in 1960. Seller got it correct.
Old 10-29-2018, 08:53 AM
mr67gp mr67gp is offline
These should be used as a pattern for reproduction of them in stainless. Unless CPR or somebody else is already doing that?
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 10-29-2018, 10:41 AM
694.1 694.1 is offline
Got used ones for a third of that
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-23-2018, 03:11 PM
flat-bill flat-bill is offline
Default gusher tubes
Are there any suggestions on removing them. I have tried several times and cannot seem to get them to move. Billk
Old 11-23-2018, 03:43 PM
Bill, PM sent
7th Firebird
57 Starchief
Old 11-24-2018, 12:05 AM
I pulled mine out with a pair of duck-billed pliers and a lot of gentle shaking. If I were to try it again I'd fill the water jacket with a citric acid solution, let it sit for a while and the try the pliers. Be gentle.
Old 11-24-2018, 09:07 AM
http://forums.maxperformanceinc.com/...56#post5683856
7th Firebird
57 Starchief
Old 11-27-2018, 10:12 PM
mgarblik mgarblik is offline
X2. With NOS originals, replica's could be produced fairly easily and sold at a reasonable price.
Old 01-12-2019, 12:32 AM
56 Batwing 56 Batwing is offline
Brought this up again to illustrate one point. In Post #3, the post says that 60 ponts didn't have reverse cooling. That is true. But the 1960 heads have a lot of casting similarities with the earlier gusher heads (1955-1959). You can slide the gusher tubes in a 1960 head with no problems. I tried and it worked. Larry Gordon @PontiacSafari.com gave me this nugget. Now I can use my 60 heads on a 58 Pontiac engine. Add the gusher tubes, water elbows on the front of the heads.
Old 01-12-2019, 12:57 AM
Stuart's Avatar
Stuart Stuart is offline
1961 heads have some remnants of the reverse cooling system as well - there's an opening on the front of the head that's filled with a freeze plug. Don't know if they can be converted or not, though.
Old 01-14-2019, 02:40 AM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
I don't know about the 61 style heads but I've got 1974, #46 heads on my 57 block [bored .125" for 370 cu in] and the tubes don't fit. Drove the car all last summer and had no overheating problems.
Roll around in the excitement
Old 12-17-2020, 11:00 PM
Rocky 389's Avatar
Just a little follow through....still driving the same car/engine with no problems.
