Old 11-18-2018, 01:50 PM
65warrior's Avatar
65warrior 65warrior is offline
Default 12BoltRearend
I very got a really clean Oldsmobile/Pontiac 12 bolt rear I bought from a local guy out of his real cool 65Olds 442 Cutlass ,he swapped out the rear for a to the door. Moser9 inch. He went through the whole thing a couple years ago it's a non posi 323gears has the bolt in axles nice brakes poly bushings, brake lines new seals and bearings no leaks super clean rear ,bolt in I'll probably never use it so 450.00
Old 11-19-2018, 04:21 AM
If I'm not mistaken, that is actually a 10 bolt 'O' type rear. They have a 12 bolt cover. Do you know if it's original to the '65?
Old 11-19-2018, 10:55 AM
65warrior's Avatar
Default Rear
It's a 66 has 12 bolt cover with 8.5 inch ring gear you can get posi traction unit for it for around 350.00.
Old 11-19-2018, 01:24 PM
george kujanski's Avatar
Where are you located?
George
Old 11-19-2018, 03:16 PM
65warrior's Avatar
Default Rear
Upstate NY Syracuse
Old 11-19-2018, 07:42 PM
Ron Landis's Avatar
Default 12-bolt
If it’s the “ten bolt twelve bolt”...it’s plenty strong...just not much in the way of gear selection offered for it.
Old 11-19-2018, 07:58 PM
It's what I have under my '68. I'd be interested in this one if it was closer and a '68/'72. Mine's a 2.78.. :/
