Old 12-05-2018, 02:19 PM
mygyver mygyver is offline
Default new head gaskets
Is it normal for head gasket to partially block oil galleys on a 1966 326 motor ?
Old 12-05-2018, 02:21 PM
https://drive.google.com/file/d/1wQ7dg7oRNnsuxPxTphlqqlTwCzL13l6F/view?usp=sharing[/IMG]
Old 12-05-2018, 02:23 PM
wanted to share some pictures but I am not qualified to do so evidently.
Old 12-05-2018, 02:36 PM
A '66 326 block shouldn't have oil galleries to the heads. Are you referring to the oil drain backs?
Dr. Thomas Sowell
Old 12-05-2018, 02:48 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Oil drainbacks are usually always partially covered. Why, IDK. They just are.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 12-05-2018, 03:13 PM
yes oil drain backs.
https://drive.google.com/open?id=1rAliSAX5pQOqzSk3QoUkdif-nlbu6Bl7[/IMG]
Old 12-05-2018, 03:18 PM
yes I mean drain backs.
Old 12-05-2018, 03:19 PM
OK. thank you
