Old 02-08-2019, 06:51 PM
JUDGE3 JUDGE3 is offline
Default Cragar SS 15" wheels on your car? or other 15" aftermarket wheel? pics please!
I'm really burnt out on ralley II wheels. restored mine but not gonna run em I decided.
anyone out there with a 70-73 and cragar ss on it? post pictures please. and other aftermarket 15" wheels to. maybe i'll see something even different that's just as awesome.
in my era the hottest wheel on the planet for years was the chrome cragar SS. think i'm going to use those I always wanted a set back then could never afford em. used to see a 72 trans am white/blue with em back then. coolest Pontiac on planet earth to me.
I wish there was a 15" cast honeycomb available i'd jump on those but I don't like the tall modern size available and don't like the super heavy original endura ones.
Old 02-08-2019, 06:52 PM
72projectbird's Avatar
I had them on my 71 before I painted it. They were 15x8 and 15x10 reverse offset.
Let me see if I have a pic of it.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-08-2019, 07:21 PM
Old 02-08-2019, 07:28 PM
If you do, DO NOT get the unilug version - they do have dedicated bolt pattern versions.
Old 02-09-2019, 10:17 AM
I like the way they look on that later model silver car. I would use the same stock size all 4 like that. same tire size all 4 also. lug specific yep.
I see cragar makes a polished aluminum ss that looks like a nice alternative as well.
I notice the stance on these. had a 1981 trans am brand new when I was 18 years old. these cars did not sit down right at the top of the tires like you see so many do claiming stock stance. I like em higher like stock new height. guess because that's how I remember they were. the lowered thing is just to low.
Old 02-09-2019, 11:00 AM
Tim john Tim john is offline
Take the time to look on Summit's website at a wheel called: Trans Am Race Engineering Superlite Wheels. This is what I plan on running come spring time. Multiple options for height, width, back space, etc. Great looking wheel that resembles late 60's SCCA racing from the Penske era.
Tim john---
ID:	505093   Click image for larger version
Old 02-09-2019, 11:16 AM
bird72's Avatar
bird72 bird72 is offline
I will be putting these on HOsprit. Has 14" rally now. Going 15x7 front with *maybe* 15x8 in back.
72 Bird
Old 02-09-2019, 11:32 AM
tom s tom s is offline
I have been running the Unilugs on my 63 Lemans for 22 years with no issue.FWIW,Tom
Old 02-09-2019, 11:41 AM
Uni-Lugs are fine as long as you use a torque wrench and check them often. They are just a PITA to deal with and should never be used when drag racing.
Old 02-09-2019, 12:07 PM
I found some old pics of my 71 before it was painted.
1987 Grand National
Old 02-09-2019, 02:25 PM
Norwood's Avatar
Norwood Norwood is offline
Back in 1976 American racing 200s (daisy) 14x7 on the front and 15x8 on the back
Old 02-09-2019, 06:08 PM
cnc's Avatar
cnc cnc is offline
I've got these on the car
I also have aset for the rear VERY similar with drag radials mounted ...
Think I got em from Summit....
ID:	505176   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 02-09-2019, 06:57 PM
muscle_collector's Avatar
I just post this on the thread in the lobby
Name:	70 ta ra4 my car 1980 _2.jpg
Old 02-09-2019, 09:03 PM
the vintage pics are awesome. the cragar site has a visual simulator that actually works good. punched in 72 formula with cragars. realistic looking and with period tires even.
rocket has some nice cragar ss-ish looking wheels also. polished salt flats pretty cool also.
but everytime I go back to the cragar ss, just so cool.
wonder what the custom machined folks get to do a 15" aluminum honeycomb? anyone out there done that? the foose show always does a one off wheel must cost a fortune.
Old 02-09-2019, 09:36 PM
I like the wheels, but they don't look nearly as good as on something with much more chrome. Earlier models are better than later models but still, they just appear added and not part of the vehicle.
Old 02-09-2019, 10:12 PM
4birds's Avatar
4birds 4birds is offline
A few pics of American Racing 15X7 200S wheels.
ID:	505209   Click image for larger version
ID:	505210   Click image for larger version
Name:	1972 Formula455.jpg
ID:	505211   Click image for larger version
Name:	NOS 15x7 daisys.jpg
Old 02-10-2019, 10:34 AM
those American racing look really great.
I see the mud flaps...…...I actually put some on my 80 ta that I bought new but tired of the look so took em off. if you drive your car a lot, as I do....and will, the firebird will nick up the lower areas quick as any ta owner knows.
so...….I did this on my 67 firebird, and will on my 72, bought the expensive clear urethane sheet and cut to fit and applied to the areas that take the paint off. can see the line some if your looking for it but its great stuff. I plan to put it on the fender flares as well, those really take a beating also.
its the same stuff weathertech sells for covering the plastic lens on vehicles headlights. put it on my Silverado truck. thick/strong/and removable. easy application.
Old 02-10-2019, 10:52 AM
Where was this taken?
Old 02-10-2019, 01:17 PM
bird72's Avatar
Fat spoke look rocks. Like painted spokes personally. I may repaint a shade darker charcoal on mine.
72 Bird
Old 02-10-2019, 02:08 PM
SS FTW
