Old 07-29-2018, 04:53 PM
bluejudge bluejudge is offline
Default Fuel Pump
I had my car running in the garage, and I thought I ran out of gas, as it stalled out. The fuel gauge was near emty, so I put 5 gallons in it. I tried to start it and it would not turn over. I checked for spark at the number one plug and I have spark. I believe the fuel pump went bad. Is there anything else I should check before I take the fuel pump out? The fuel pump is at least 28 years old and I would not be shocked if it was the original. Thanks, Marc.
Old 07-29-2018, 05:46 PM
300deluxe's Avatar
300deluxe 300deluxe is offline
Take air cleaner lid off, look down carb and move throttle to see if it squirts.
1968 Lemans 350 HO
55 Chevy 210 2 door post, future Two Lane Blacktop car
Old 07-30-2018, 06:29 AM
Sounds like a fuel pump failure, diaphragm ripped or spring or pin on pivot let go. I’ve had the best luck with spectra premium pumps, Canadian made versus China. I gave up on nos GM pumps because they seem to have high failure rate, maybe just old diaphragms or not ethanol friendly.
The other thing that can mimic a pump failure is the cam eccentric coming lose and shearing its pin. More common on recently rebuilt engines rather than untouched engines.
Old 07-30-2018, 05:57 PM
Thanks guys. Since I am there I might as well change the rubber hoses that are there. I believe the fuel line ls 3/8 and should get the green clamp and the return line is 1/4 and should be the red clamp. I am not sure which pump to order now. Does the Spectra pump look like the factory model? I think it is number SP1046MP. I usually get the factory stuff when I can. I think the one in the catalog N128RC is (AP) after product. Thanks, Marc.
Old 07-30-2018, 08:32 PM
The spectra pumps I’ve bought for my cars (69 with AC so includes a return line) look like a Delco pump. I don’t mean they are exact to the dimples but the look stock and all the fittings are bang on so no fitment issues with the steel line to the carb.
If you’re doing the rubber hoses there might be a good time to do the ones at the he tank too.
Old 07-30-2018, 10:24 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
check for a ground fault also
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 11-12-2018, 08:07 PM
Finally changed the fuel pump. Started it up, then the accelerator pump on the carb started leaking. Maybe I will get the car driving before we get some snow. Time for a carb rebuild.
Old 02-04-2019, 03:05 PM
So I changed the fuel pump and had the carb rebuilt everything was great. I was driving around fine then the fuel gauge started to act up, it was buried past full. I figured it was the ground wire by the tank, so I got a wire brush and cleaned all around it, but that did not work. I thought I had 5 gallons in the tank but I was wrong. Ran out of gas in the street. I had to call my wife to bring me my fuel jug,(which she will never let me forget). I dropped the tank thinking the ground wire was broke off, but it was good. Any suggestions before I put it back. I do not have the tar paper in between the tank and the vent tube looks like it does not have the filter in it anymore. So I am going to order those. I would love to complain, but this is my baby and everything is about 50 years old. Thanks, Marc.
Old 02-05-2019, 12:23 AM
Where can I order spectra fuel pumps
Old 02-05-2019, 12:33 AM
In Canada all the main auto parts chain carry them but you have to ask by name. Spectra does most of the repro gas tanks too. I’m sure most major auto parts chains have n your area carry them. Maybe try summit too, often cheaper than the local auto parts place.
Old 02-05-2019, 04:00 AM
I went right on the Spectra website and I think I paid something like $12 for the fuel pump. It was the cheapest price around. Marc.
Old 02-05-2019, 08:46 AM
Ram4king's Avatar
Ram4king Ram4king is offline
Change the fuel sender. I've had to change alot of them the last few years.
You can buy them from auto stores
Old 02-05-2019, 08:06 PM
Don, do you think that is the issue I am having with the fuel gauge, or do say to change the sending unit because the tank is out already. Thanks, Marc.
Old 02-16-2019, 05:18 PM
Okay I changed the sending unit turned the car on and it went to empty. I put 5 gallons in the tank and it is still on emty. Started the car up and it is still on empty😡. Anyone have any suggestions? By the way I ordered the spectrum sending unit and it said made in china😡😡😡. Thanks, Marc.
Old 02-22-2019, 12:37 PM
Default Fuel sending unit.
I want to send out my original fuel sending unit to get rebuilt, anyone have a recommendations? Thanks, Marc.
