Old 03-03-2019, 03:20 PM
R68GTO's Avatar
R68GTO R68GTO is offline
Default GTO parts for sale
I am purging my Pontiac parts stash. Everything listed is for a 68 GTO convertible except where noted. Parts range from repro NIB to unrestored original condition, some are noted in the description.
I will be at the All Pontiac Swap Meet at the Franklin County Fairgrounds in Hilliard, Ohio on March 10. I prefer to sell there vs online to save the hassle of paying for or arranging shipping. Below is a fairly comprehensive list of what I am bringing with me, there are other small items that will also be there that are not on the list.
Jim
N333CB fan belt (new) - A/C - $38
N333GB alternator belt (new) w/AC - $38
Door edge guards - original - $75
Cowl screen (repro) and brackets (orig) - $30
Quarter glass trim (vert) - $15
Convertible top cylinder - $75
Ignition points, wire, and grommet - $10
Fuel tank (orig) - $20
Convertible frame parts - $20
Rear quarter glass (orig hardtop) - tinted - $75
Rear quarter glass (new - vert) tinted - $200
Brake booster (repro) - needs rebuilt - $40
Ralley II wheel center caps (red PMD) - $100
Convertible top pump - original, needs rebuilt - $75
Convertible top pump reserveoir plug - $1
Radiator to core support isolators (repro) - $5
Fuse block to power window wire (repro) - $5
Fuel pump fitting - $5
Throttle spring - $2
Thermostat 180 degree - $2
Oil pressure sender - $5
Steering column bracket adapters - $5
GTO floor mats (aftermarket) - $2
Front end rebuild kit (unopened box) - $350
Air cleaner housing (orig) - $140
Pinchweld moulding clips - $15
Parking lamp lenses (orig) - $20
Fuel tank sending unit (new) - $15
Power top motor harness (M&H) - $20
Air cleaner breather tube (orig) - $1
AC hose (repro) - $20
AC condensor brackets - $5
Convertible top cable (orig) - $15
AC muffler (orig) - $2
Turbo 400 shifter cable (orig) - $2
Bucket seat bracket (orig) - $2
Alternator strap (orig) - $10
Distributor vacuum advance - $10
Bucket seat back panel brackets (orig) - $2
4 gang power window switch - $40
Rear quarter marker assembly (orig) - $10
Power antenna nut (repro) - $5
Disc brake distribution block (new) - $40
Fan clutch w/bolts - $10
Convertible top frame staple insert (roll) - $10
Driver door latch (new) - $65
Tilt column turn signal switch (new) - $35
Hideaway headlight switch (new) - $75
Convertible top motor mounting grommets - $5
Turn signal lever (new) - $20
Flasher knob (new) - $5
Splash shields (new) - $10
Pontiac script visor mirror (new) - $25
Voltage regulator cover (new) - $2
Hood insulation pad clips (new) - $2
Dash insert clips for dash pad (orig) - $20
Harrison AC box sticker (new) - $2
Front end bolt kit (new) - $20
Convertible door strikers (new) - $25
Gas cap - $2
AC mounting hardware & spacers (new) - $10
Emergency brake parts (orig) - $5
Quadrajet throttle arm (orig) - $2
Alternator - $10
4 barrel “140” intake - $125
Misc. interior screws (new) - $5
Seat lock hardware (orig) - $5
Front core support bolts & nut plates (orig) - $2
Blower motor vent tube (orig) - $5
Parking brake cable set (new stainless) - $170
R68GTO
1969 Camaro COPO 427 "RAT'S NEST"
Old 03-07-2019, 06:39 AM
bkmont's Avatar
bkmont bkmont is offline
If you decide you would want to ship something, I would like to have the 68 door edge guards for my 68 convertible if they are in good driver condition.
Thanks,
Bryan
Old 03-09-2019, 05:23 PM
R68GTO's Avatar
I'll let you know if I still have them after tomorrow's swap meet in Hilliard.
R68GTO
Old 03-10-2019, 05:23 PM
R68GTO's Avatar
Default Updated list - items left are still for sale.
Door edge guards - original - $50
Temperature sender - $5
Power top motor harness (M&H) new - $20
Gas cap - $2
Alternator - $10
R68GTO
Old 03-11-2019, 05:29 AM
bkmont's Avatar
Thanks!
Old 03-18-2019, 06:26 PM
R68GTO's Avatar
TTT - updated the list, removed the sold items and adjusted a few prices. If you're interested in an item, I'll send you pics.
Quarter glass trim (vert) - $10
Convertible top cylinder - $65
Rear quarter glass (orig hardtop) - tinted - $70
Rear quarter glass (new in box - vert) tinted - $175
Ralley II wheel center caps (red PMD) - $90
Front end rebuild kit (unopened box from Ames) - $300
Air cleaner housing (unrestored with PP silkscreen) - $130
Driver door latch (new) - $60
Convertible door strikers (new) - $20
Alternator (1977 reman)- $10
4 barrel “140” intake (Dec. 1967 date)- $120
Parking brake cable set (new stainless set from Just Right) - $160[/QUOTE]
R68GTO
