Old 04-15-2019, 04:20 PM
GTOGEORGE's Avatar
Originally Posted by thirdgen455 View Post
That's what I used. It has acetone in it and should have mixed with the gas.
Hate to hear you had a bad experience with it.
I thought i mixed it good enough........guess not! Lesson learned. LOL!
Actually with a roots blower you shouldn't need an power additive fuel....except for certain classes.
GTO George
Old 04-16-2019, 08:35 AM
Well, the nitro-methane on-demand BOOST sounds risky for slug venting.
I'd use a vacuum switch that only applies nitro-methane while under load in "3rd gear", and perhaps reduce timing?
Old 04-16-2019, 10:08 AM
Vacuum switch probably good idea.
Timing not sure about.
Nitro may need more timing?
Old 04-16-2019, 10:15 AM
Forgot about this engine:
See Thru Engine
This is what you need to test your idea?
Maybe put a clear Pontiac head on and try it?
