Old 04-18-2019, 08:25 AM
TAQuest TAQuest is offline
Default New HEI Problem
I bought a new HEI for my Pontiac 400 and I noticed something I haven't seen before. Looks like a bad part. Want to check and see what the consensus is on this rotor that has the contact pointing up instead of out. Will post a picture link in the next post.
Old 04-18-2019, 08:27 AM
https://share.icloud.com/photos/0OfO...r_Township,_MI
Old 04-18-2019, 08:46 AM
steve25 steve25 is online now
That needs to be bent over 90 degrees , but still have the arc to it.
Do not use it the way it is!
By they way why did you not post that picture right to this web site?
Old 04-18-2019, 08:53 AM
That's what I thought.
Also, the set of plug wires I bought, the shortest wire doesn't reach any plug.
I hate returns.
Old 04-18-2019, 08:54 AM
The reason I posted the pic the way I did is because it's on my phone.
Old 04-18-2019, 09:40 AM
This is becoming more and more prevalent these days.
I'd say that one is more of an extreme that I've seen so far. Used to be two rotor tiplengths for the points distributors, early and emissions. Emissions being he shorter of the two. Nowadays it seems almost as if all points rotor tips are the "emissions" length.
That's an HEI rotor obviously, but they too seem to be using shorter tips(larger rotor air gap).
For educational purposes take an old cap and cut a window in the side exposing the cap terminals. Put it on that distributor and see how far away the tip is from the terminal.
Amazing what we are paying good money for and being supplied these days. It's just pathetic.
That's the worst I've seen so far, and I've seen one or two ...
Old 04-18-2019, 09:44 AM
Comparing a working rotor with the defective one there will be about an 1/8 inch extra gap.
Another thing I didn't like about this HEI is the driver for the oil pump doesn't have a chamfer on it like a GM one. This is definitely a reject.
Old 04-18-2019, 09:45 AM
And as Steve said it should be bent over, but it's not , and you should not. Just get a different rotor.
Even bending that one won't get you close enough to the cap terminals like it should be.
Although the ol HEI will jump the gap, it'll be hard on the coil, and cause it to start hard frequently.
Old 04-18-2019, 09:57 AM
No way I'm putting a different rotor on this. It's heading back where it came from. How and the heck can a manufacturer not notice this obvious defect? I get the feeling they just are flinging junk at us. I'm flinging it back.
Old 04-18-2019, 10:12 AM
Hell, while your at it....
Look inside and tell us if you see what's lubricating that top bushing.
Go ahead. Have a look.
Tell us what else you don't see up top in there.
You're right, most of these places are just slinging stuff at the wall just to see what sticks. Not all... but most.
Kinda sad. Keeps me busy but, theatres a reason some of this stuff is as cheap as it is.
It can be made suitable for use though.
Old 04-18-2019, 04:22 PM
Schurkey Schurkey is offline
WHAT BRAND of HEI is this?
WHO did you buy it from?
Old 04-18-2019, 04:26 PM
Right. Should have posted that.
It's this one;
https://www.ebay.com/itm/Pontiac-V8-...gAAOSwRUdbv3H6
Old 04-18-2019, 04:29 PM
ck67goat ck67goat is offline
Please post the brand name so that we can all stay away from this kind of junk. Thank you.
67 GTO street car - 428, roller cam, TH400, GV OD, through mufflers Best ET - 11.44. Best MPH - 116
67 GP Convert 428 HO Project Car in process
67 GP Convert 400 (not sure yet if parts car or future project
68 Catalina Convert 400 - all original 135k miles
Here is the plug wire set that one wire is so short it doesn't reach any plugs;
https://www.ebay.com/itm/New-Dragon-...pe!48706!US!-1
Old 04-18-2019, 04:31 PM
Check out the item on eBay with the link above. In the description it says Gearhead brand.
Old 04-18-2019, 04:37 PM
It's this one;
Missed your post by a second. Those appears to be overseas sourced junk conspicuously in colors similar to a good name brand. Stick with well known brand named parts, especially for ignition and you'll get many years of worry free service. I've rebuilt factory GM HEI's and typically used delco or accel parts with good success and longevity on mild performance builds. If you cannot find a factory distributor or need more performance, I also recommend MSD distributors and have had zero problems with their parts.
Old 04-18-2019, 05:04 PM
It's this one;
Old 04-18-2019, 05:21 PM
abefromen's Avatar
abefromen abefromen is offline
It's this one;
Reading all the bad feedback would have been enuff for me to look elsewhere.......
