Old 07-17-2019, 11:55 AM
not a catalina not a catalina is offline
Default neutral shift ?
I swapped a turbo 400 into my 64 bonneville column shift car can anyone tell me what I can use to replace the original neutral switch thanks
Old 07-17-2019, 07:43 PM
Stuart's Avatar
Stuart Stuart is offline
I have no experience with the swap, but if you're keeping the original shift lever can you just adjust the position of the original neutral switch?
Old 07-17-2019, 08:19 PM
CatalinaMike CatalinaMike is offline
What trans was in it previously? Did you keep the column shifter or move it to the floor?
Old 07-17-2019, 09:07 PM
Poncho60 Poncho60 is offline
Stock trans should be Jetaway (super hydro). The neutral & park positions on the turbo 400 are different than on the super hydro. Column shift.
Old 07-17-2019, 09:37 PM
I kept the column shifter thought there might be anotyer switch I could replace the original one with and make it easier on myself
Old 07-17-2019, 10:51 PM
Stuart's Avatar
Yes, the super hydro is PNDLR and the TH400 is PRNDL, but the neutral positions aren't that far away from each other - that's why I was wondering if the switch position could simply be adjusted, or perhaps modify the mounting bracket to rotate it around a little.
Old 07-18-2019, 12:23 AM
Bill Hanlon's Avatar
Park should work on either one. You may find that the 400 will also start in reverse.
Old 07-20-2019, 01:50 PM
Ziggy Ziggy is offline
I sent you a PM.
Old 07-25-2019, 08:14 AM
Willshire's Avatar
Willshire Willshire is offline
I bought my neutral safety switch for a 66 and up floor shift to swap a slim Jim to a 2004r. Not sure how the column shift differs
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 07-27-2019, 12:51 AM
alleyCat alleyCat is offline
Ok here I can help. I used a 64 Buick neutral safety switch to convert my 61 Safari to a T400 detent. However I could not find anything to convert the indicator on the column. I can get the part number of the box if you need it. At least the back up lights are actually in reverse now. Its been a couple years so I cant remember if I had to swap any wires around but I dont think so
Old 07-27-2019, 01:10 AM
Default neutral switch
alley cat Iam trying to get the car to start in neutral it currently starts in park and reverse it is a back upl lite delete car if this switch will do this please send me the part number by the way were almost neighabors IM in chgo near devon and harlem thanks alot
Old 07-27-2019, 03:56 AM
Ha ! I am near Harlem and Oakton. I will check later today
Old 07-28-2019, 09:05 AM
389 389 is offline
I kind of like being able to start my car while its moving should it stall.... I habitually check what gear Im in and put my foot on the brake when I start..
Check out the Lokar set up..
