Old 08-26-2019, 10:35 PM
Bill Hanlon's Avatar
Default Need an extension cord for Bosch relays
I'm trying to troubleshoot an electrical problem around a Bosch type (cube, 5 pin, 30/85/86/87/87a, etc) relay that is buried way up in the dash. If I could get a meter on the relay pins I could figure it out, but there is no way I can get to it.
I could make one, using the female end with wires that ships with the relay when you buy a new one, but no one sells a male end that I can find. I tried opening up a relay and gutting it to get a male end, but ended up destroying it.
Does anyone make an actual "extension cord" that has a Bosh male 5 pin plug on one end, at least 3 feet of 5 conductor wire and a Bosch female 5 pin plug on the other end ?
Old 08-28-2019, 05:24 AM
Can't you just put spade terminals on the end of the wires?
Old 08-28-2019, 07:00 AM
If I could see the socket that the relay plugs into, but I can't. Last night I started working on a solution using spade lugs set in potting compound (actually liquid epoxy) held in a relay cover for proper spacing. Should know tonight if it works.
Old 08-28-2019, 02:08 PM
You can cut the top off a relay, dig the guts out, and solder a relay socket with a pigtail to it.
Old 08-28-2019, 04:49 PM
That's plan B. Already have the relay torn apart, waiting to see if plan A works. Still can't believe nobody makes one.
Old 08-29-2019, 06:59 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
The testing harness does exist via IHC / Navistar Test Equipment PN ZTSE4596, although it is not cheap.
The overall length socket to socket is about 10".
https://navistarservice.snapon.com/S...umber=ZTSE4596
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
Old 08-29-2019, 07:59 AM
You're not kidding that ain't cheap!
Old 08-29-2019, 09:18 AM
Just what I need if it were about 1/10th the cost and 2 feet longer.
Epoxy is setting up on my second attempt now. The liquid epoxy was too thin. I'm trying PC-7 now.
Old 08-30-2019, 01:33 PM
I made up this 3 foot long "extension cord" for cube relays. The female end is just a standard cube relay socket. Five wires running to the male end, covered with shrink wrap. The male end is five 3/16" crimp-on spade quick disconnects sitting in PC-7 epoxy contained in an old cube relay cover. Works good.
Figured out my problem in just a few minutes once I had this tool. The main power feed for the A/C system should come to one of the relays, but wasn't making it there. Turns out there was a plug that wasn't shown on the schematic that was about 6" upstream of the relay, hiding behind the A/C unit under the dash. It had come loose.
Old 08-30-2019, 02:31 PM
Nice! And nice!
Well, that was a good effort, and will provide troubleshooting assistance down the road too!
