Old 10-12-2019, 06:57 PM
ErikW's Avatar
ErikW ErikW is offline
Default Another Turbo Cam "What If"
How do you guys think a 114LSA Old Faithful cam would work in a twin turbo 468 With Edelbrock round ports and Fuel Injection using a Victor EFI /Elbow and 102mm LS Throttle Body?
(Old Faithful specs: 236/245 dur @ .050" lift .578"/.582" lift 114 LSA)
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-12-2019, 07:26 PM
73 TRANSAM 73 TRANSAM is offline
I would try it but that cam would probably be done before 5500 rpm.
Old 10-12-2019, 09:26 PM
ErikW's Avatar
Even in a turbocharged application? It pulls hard to 5900 in my wifes car N/A with the 112 LSA
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-12-2019, 11:01 PM
AIR RAM AIR RAM is offline
Originally Posted by Half-Inch Stud View Post
Is there a dividerin the Log to isolate 2&4 from 6&8? ( easily done)
Likewise a divider in the Log to isolate 1&5 from 3&7 (can be done)
I will ask this question however from the sounds of this the gains would be minimal... Perhaps I can get steve on line to answer this directly.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 10-13-2019, 12:19 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I have a very similar cam 579 lift little more duration, single turbo, rev limiter set at 6500 have bounced it off of that many times. I try and shift @ 6000 but spinning sometimes delays my shift while getting the car under control.
Old 10-13-2019, 12:52 AM
ErikW's Avatar
So, would you say it's doable? And what kind of power are you making with it?
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-13-2019, 01:04 AM
firechicken's Avatar
firechicken firechicken is offline
My 462 pulls hard to over 6000 with a 224/224 114ls at 18 psi. My cam is installed straight up 114 IC.
Old 10-13-2019, 02:41 AM
krisr's Avatar
krisr krisr is offline
In a naturally aspirated sense maybe, but in a turbo application it would be great with the rising torque curve of boost. More boost the more it pushes it.
Old 10-13-2019, 05:27 AM
charlie66's Avatar
The size of the cam is fine. Its the opning and closing points that are critical. What are they??
My Half AN Injun.....
Old 10-13-2019, 09:32 AM
Some fella commented that a 4/7 swap cam would be good with the LogHeaders and...he may be quite right!
As if no Reversion could occur. The way an H-plane intake provides inhale isolation.
Will need to break out the flow charts to see about that.
Old 10-13-2019, 09:46 AM
ErikW's Avatar
Here ya go
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-13-2019, 10:23 AM
charlie66's Avatar
The exhaust closes a little late , but its not too bad . Id try it if thats all i had..
Its close to the lift and duration i use ..
Should work...
Old 10-13-2019, 11:34 AM
JSPONT's Avatar
If I had it I would try it, I can only guestimate by my MPH at the end of the 1/4 cause I spin 1st and 2nd, but at 11-12 psi I trap at 145 mph. Car is close to 4000 lbs with me in it. I would say I put down 700-800. I have not turned it up because on the street it is a waste.
Old 10-16-2019, 08:38 PM
er455 er455 is offline
I have that cam on my single turbo 468 except it’s on a 112 LSA with the 4/7 swap it pulls hard to 5800 on 12 lbs of boost ...we installed it 4 degrees advance as well ...
Old 10-17-2019, 06:44 PM
ErikW's Avatar
Thanks, I think I'm going to try it. Dave at SD
performance is doing me up a set of 95cc 325cfm Edelbrocks with T washer inserts. She should make good power.
1964 GTO
9.76 @ 137mph
2009 G8 GT
