Industry Stuff new repro's, updates, other info.
Old 11-15-2019, 12:59 PM
dataway's Avatar
dataway dataway is offline
Default 68-72 Core Support
People selling the reproduction 68-72 GTO core support should make buyers aware that besides the modifications necessary for a 68, that the support has to be totally reworked to fit.
The top plate and the bottom rail on the reproduction are parallel, on the OEM piece the support tilts 9-10 degrees forward with the bottom rail being horizontal and the top plate 9-10 degrees off horizontal. To fix this requires drilling the welds and removing the bottom rail and rewelding it to achieve the proper tilt of the core support. Rewelding requires additional metal to be added to fill the gap left at the bottom after positioning it correctly.
Image below is from the 69 assembly manual that shows the proper lean angle.
On the reproduction the bottom rail (point BD) and the top plate (point BC) are both exactly horizontal.
This is a major flaw and this item should not be sold without the buyer knowing it will require extensive work to fit properly.
Old 11-21-2019, 04:59 PM
Two_70_Converts Two_70_Converts is offline
That's good information. How is the fit otherwise?
Old 09-10-2020, 07:10 PM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
So I am guessing the same would apply to a 70? Wondering if it might be better just to replace the typical rust under the battery tray.
1970 GTO
Originally 400, M20, Atoll Blue, PS, PDB, A/C
Now has 461 stroke, Keisler RS600 5 speed.
Just a fun driver
Old 09-10-2020, 08:35 PM
Typical rust is at the 2 lower mounts.
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 09-11-2020, 12:22 AM
OG68 OG68 is offline
There are patch panels available for the lower mounts. Bought mine from Inline Tube.
The Following 3 Users Say Thank You to OG68 For This Useful Post:
Old 05-10-2021, 11:15 PM
3goats's Avatar
3goats 3goats is offline
There is a few more issues with these POS. patch panels.
The holes for the clips to hold valance bolts are off. Too far to drivers side. Out 1/2 a hole.
The hole for the plastic wire protector for headlight wires is too big. Need to rework.
The top is not spot welded in the right place. Off about 1/2 inch to Drivers side. Found this out when aligning front fenders.
Sometimes is just as much work to repair your old one if not too far gone or spend hours on these.
I guess if its just a driver or race car you could just bolt it on but you won't like the alignment if your at the least bit fussy.
Good thing they are fairly cheap!
The Following User Says Thank You to 3goats For This Useful Post:
Old 05-11-2021, 10:01 AM
dataway's Avatar
Incredible that they are still being sold and not one vendor mentions how bad they are. But then most people are probably just building drivers where they hammer and bend them into place and never know the difference.
But yes, ... way easier to fix an OEM piece if just the mounts are rusted out than to rebuild one of these disasters.
Old 05-13-2021, 02:58 PM
craigs69's Avatar
craigs69 craigs69 is offline
Agreed. Absolutely fix the OEM piece.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
