Old 01-06-2020, 10:21 PM
grd777 grd777 is offline
Most likely it was, and has the newest steel version.
I have the original off my '73 Formula project, but like many, it needs some repairs. I bought a heat stapler and 3m epoxy to fix it, but its a bit down the list.
if i buy the abs valance can i used my amber lights
Old 01-07-2020, 12:08 AM
Red Goat's Avatar
Red Goat Red Goat is offline
Originally Posted by cnc View Post
Could someone post a pic of the centre support your referring to??
So the centre support is on the steel Valance or the plastic or both???
I'll take a pic of the bracket on my survivor car for you tomorrow. It is used on the plastic valance in the center. I believe Ames sells a repop of the bracket that one of our very talented member produces.
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
The Following User Says Thank You to Red Goat For This Useful Post:
Red Goat's Avatar
Yes
Old 01-07-2020, 05:43 AM
Norwood's Avatar
Norwood Norwood is offline
Plastic v brkt
Old 01-07-2020, 09:57 AM
77 Canamman's Avatar
If the PP plastic valance is good enough for BWB's Formula, then it shall be more than adequate for my blue car.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-09-2020, 01:25 AM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Thanks guys for the great response and information. It turns out the valance I have on my car is metal and I think off a 71-72. So I ordered a 73 valance from Ames. But it doesn't look like the old amber parking lights won't work with in the new valance? So any suggestions? Didn't realize it was going to go this deep into changing out more parts! I can try to get some pictures if needed.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 01-09-2020, 03:12 AM
Formulabruce's Avatar
You will need the Amber capsules,for later 72 and 73 . Ames sells them. You will also need a front light harness for this style light capsule. Ames has those as well.
Old 01-09-2020, 08:33 AM
cnc's Avatar
cnc cnc is offline
Originally Posted by Norwood View Post
Plastic v brkt
Great thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
