Old 01-11-2020, 09:50 AM
trshman's Avatar
trshman trshman is offline
Default LED Tail light problem
Good morning,
I just bought Sylvania Automotive #1157 LED tail/brake light bulbs to replace my incandescants. I installed one then tried it. The light it gives off is less than my original. I checked Sylvania's website and the #1157 they show doesn't even look like the ones I bought (see attached). Also they mention the possible need for some kind of a current balancer when changing from incandescent to LED.
Anyone have any experience with these things? Any help would be appreciated.
You all have a good day, trshman
Old 01-11-2020, 11:21 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Hopefully the problem is a simple fix. I'd like to convert to LED also.
Old 01-11-2020, 05:03 PM
trshman's Avatar
Default The Internet Comes Through ! ! !
Hammertime Mike and anyone else who read my thread. The internet came through again with an answer, specifically You Tube. Since there weren't a lot of responses to my post I decided to do a search and found a guy from Pennsylvania that tested 4 (that's right FOUR) variations of the #1157 LED bulb, I believe ALL from Sylvania plus an incandescent.
It answered all my questions regarding the bulb and at the same time raised a question as to whether the LED's are worth the extra bucks at all. The differences in light generated is a function of the design of the LED's housing but you can see that for yourself(selves).
Anyway, here's the link. The guy isn't Steven Spielberg and like a lot of amateur videos there are times I think he takes too long to get to the point but the bottom line is he eventually provides all the info I need to make an informed decision, so for that I thank him. Here's the link. You all have a good one. trshman
https://www.bing.com/videos/search?q...6FORM%3DVDVVXX
Old 01-11-2020, 06:04 PM
1965gp 1965gp is offline
I put these in my 72 Firebird. One was bright as could be and one was dim. Just playing around with it I flipped the bulb 180 deg and it lit up bright like the other one.
I’ve heard these lights take so little current that they can light up taking unconventional/ alternate paths. Grounds are apparently a big deal for these.
Old 01-12-2020, 03:56 AM
Geoff Geoff is offline
LEDs come in varying degrees of brightness. The Cree type LEDs are the ones to get.
I got mine from superbrightleds.com. They had a choice of brightness. Mine are brighter than the original incandescent lamps.
Old 01-12-2020, 05:38 AM
I am running the same Sylvia is ones you get at the local parts store
Old 01-12-2020, 09:59 AM
trshman's Avatar
I found Sylvania #1157R LED's at Autozone. It's one of the 4 LED's the guy tested in the video and produced the most light but more importantly the greatest difference between normal light and when braking.
