Old 01-24-2020, 01:41 AM
pont406's Avatar
pont406 pont406 is offline
Question SR Service replacement block number
I was wondering if anyone knows what the numbers after the "SR" stamped on the front of the block mean? a part number? or just a casting sequence number?, I know its not the casting date or block casting number as they are in the normal locations
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 01-24-2020, 07:24 AM
Can you post those numbers and the block casting number and date?
Also is it a 3 inch or 3.250" main Bore?
Old 01-24-2020, 08:51 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
I’ve been recording SR block numbers for quite so time. What I can say is that they seem to jump around. They all start with “SR8” which is followed by four or five digits.
The “SR” stands for Service Replacement. The “8” signifies 8 cylinder (A “6” was used in this place on OHC-6 engines). And the numeric sequence was the engine serial number. At first I thought the serial numbers were sequential, but I don’t believe that to be true any longer. They’re generally 10,000 or less.
It’s interesting to note that SR blocks were sold as a “fitted assembly.” That means a machined block with main caps and pistons/wrist pins.
Can you share your numbers?
Old 01-26-2020, 02:20 PM
pont406's Avatar
here' s the pics 62 389 block
ID:	530081   Click image for larger version
ID:	530082   Click image for larger version
Old 01-27-2020, 07:37 AM
Can you post up a picture of either side of the block back by the bell housing flange?
Does the block have a reinforcement wing cast in from the lower side of the rear deck to the bell flange?
Old 01-27-2020, 09:22 AM
1funride 1funride is offline
Were the SR blocks made from stronger castings or the lightened 557 castings?
Old 01-27-2020, 11:36 AM
Old Goat Racer's Avatar
Here are some pics of my 455 4 bolt main SR block.
SR8 1758
For Rocky
The guy I bought it from installed an NOS SD crank and TRW forged pistons. And topped it off with 455 SD heads.
I don't have the heads.
ID:	530173   Click image for larger version
Everybody knows somthin.
Nobody knows everything !
Old 01-27-2020, 01:22 PM
pont406's Avatar
yes it has them
Old 01-27-2020, 01:27 PM
Then that is a casting of the 325A trophy block that was used for both 389 and 421 motors.
Old 01-27-2020, 01:53 PM
Most are far stronger than the 557 blocks. In this case, it is a VERY strong block.
Dr. Thomas Sowell
Old 01-27-2020, 02:07 PM
unruhjonny's Avatar
this thread might also be of some assistance:
https://forums.maxperformanceinc.com...d.php?t=826840
1970 Formula 400
Old 01-27-2020, 03:31 PM
Thank you!
Old 01-27-2020, 03:32 PM
SR8 1758
For Rocky
Thank you!
Do you happen to know if it has 4 bolt main caps?
Old 01-27-2020, 03:41 PM
And as a note to all following this thread, my comment earlier about SR block number sequencing is visible here.
Pont406's SR block (cast Jan 16 1962) is numbered "1967" while Old Goat Racer's 455 (cast Oct 11, 1972) is numbered "1758".
I'm trying to determine how Pontiac decided upon their numbering system.
Old 01-27-2020, 03:50 PM
have a 428 4bolt SR in the rack, will get you the number Rocky.
Old 01-27-2020, 04:03 PM
Thanks, Roger.
If you're able to snap a pic of the casting number, cast date, and SR stamping, I'd love to add them to my info. Also, if possible, can you tell me if it's two-bolt or four-bolt main caps?
Old 01-27-2020, 04:09 PM
Thank you!
YES it does.
Old 01-27-2020, 04:29 PM
Rock, it's a 4 bolt, will take some pics.
Most SR 400's were the thicker web earlier block castings. that stated, 500557 casting SR 400 fitted blocks were built. Picked up a 557 SR fitted block many years ago, ended up using it in a '77 Y81 project.
Old 01-27-2020, 05:13 PM
YES it does.
Thank you. I'm finding that all SR 455s from the 72-74 era were equipped with 4-bolt main caps.
Old 01-28-2020, 03:10 AM
pont406's Avatar
My block is also 4 bolt main
