Old 02-22-2020, 03:35 PM
KGTO's Avatar
KGTO KGTO is offline
Unhappy Engine been in storage, now wont roll over
Pulled my running engine out a few years back so we could do a frame off on the car. I never meant for the engine to be out this long and rather than backing off all the rockers I would just spin the motor over every few months or so.
About a year ago went to do this and it went most of the way around and STOPPED. Roll it back and did the same (about 270°) . So I've yanked the covers, backed off all the rockers (solid cam) still hits. Pulled the distributor, still hits. I'm at the point that the pan or timing cover needs to come off. Any thoughts on what the hell the problem is?
I had maybe 1000 miles on the engine after going through the rods and mains. I did have 150 shot that I'd use once in a while but it ran great. Thought maybe I should bore scope the cylinders first just in case.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 02-22-2020, 03:59 PM
gogtogo's Avatar
gogtogo gogtogo is offline
I had a similar situation years ago. Ended up a fork on the oil pump shaft broke. Was running when removed. All I can figure is a combination of 20w 50 oil, stored on concrete floor in unheard garage in Western NY. I turned it over once a month for over a year and just stopped.
Old 02-22-2020, 04:23 PM
KGTO's Avatar
Interesting...although I drained the oil out of mine. I suspected the driveshaft but pulled the distributor and it turns easy with a screw driver
1964 421 GP-Sold
Old 02-22-2020, 04:36 PM
Stuart's Avatar
Stuart Stuart is offline
Maybe a mouse nest inside the engine someplace?
Old 02-22-2020, 04:40 PM
DOC DOC is offline
Maybe a rust edge near a top ring and the particular piston cannot go higher than that edge or something got in through the exhuast port/ valve and is sitting on top of a piston.
Old 02-22-2020, 05:00 PM
KGTO's Avatar
Top of engine is sealed via lift plate.. I guess something could be in the cylinder.
Would a rust line feel like metal to metal?
1964 421 GP-Sold
Old 02-22-2020, 05:11 PM
Exhaust blocked off too?
Easy for humidity to get in. Spay some oil or something in each cylinder let it sit for awhile then try turning it?
Old 02-22-2020, 05:19 PM
KGTO's Avatar
Hi John
It was taped for a while but been off a while now too. I blew air in cylinders and exhaust and no debris or anything. I sprayed WD40 in earlier and just did again. Man I hate to pull this sucker apart
Whatever it is its solid.
1964 421 GP-Sold
Old 02-22-2020, 05:58 PM
Scott65's Avatar
Scott65 Scott65 is offline
Check the flexplate area, in case something got wedged in there?
'65 Tempest 467 3650# [email protected]
Old 02-22-2020, 06:24 PM
Scott Stoneburg's Avatar
Were the rockers loosened all the way when it was put into storage? If not you may have a valve that is hung open and the piston is making contact
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 02-22-2020, 06:25 PM
KGTO's Avatar
No the rockers weren't backed off ... they are now and it still hits
1964 421 GP-Sold
Old 02-22-2020, 06:27 PM
KGTO's Avatar
The history with this car is everything ends up being painfully simple stupid. So its gotta be something dumb
1964 421 GP-Sold
Old 02-22-2020, 06:49 PM
Darren 639's Avatar
Darren 639 Darren 639 is offline
With all of the rockers backed off are all of your spring Heights the same all the way across on each cylinder head? If one is hanging down obviously that’s the one that is stuck I’ve had this happen to me before in the past. And a one other thing was a mouse crawled up the header tube and put birdseed on top of the piston and the engine stopped dead.
John Langer's Avatar
John Langer John Langer is offline
Fill every hole w wd-40 and let it soak for a day or 2. If that doesn’t work, get a bigger breaker bar.
Old 02-22-2020, 06:52 PM
Darren 639's Avatar
One last thing is you could get those borescope cameras that go down in the cylinder area through the spark plug hole and make sure your walls aren’t rusty or any debris on top of the piston. I bought a camera on Amazon that goes to my smart phone it has a light on the end and it is amazing. it also came with a little mirror that you could screw onto the end of the camera to see the opposite side like your valve area.
Old 02-22-2020, 08:12 PM
I think the oil/WD40 thing will work.
But the quote above would be an easy thing to check. Never know what may have been forgotten or happen during the down time. Flexplate sitting on that cart? Maybe left some bolt in the flywheel for a stop to unbolt damper bolt? Vice grips clamped to flexplate? As said, mice can do some weird stuff.
Old 02-22-2020, 08:23 PM
Another idea. Are all the accessories on it like in the pic? Maybe one of them is 'sticking'. Try taking all belts off?
Old 02-22-2020, 11:11 PM
GTO's Avatar
GTO GTO is offline
Guy posted a picture of a mouse 'stash' in his race car cylinder. Headers were not plugged and a mouse crawled in through the header/valve and filled it with seeds.
Runner Up Q16 Norwalk 2013!
Old 02-23-2020, 12:35 AM
Darren 639's Avatar
When a mouse put seed on top of the piston on my motor The cylinder got damaged. most likely the cylinder walls will Be etched with urine. when I went to start my car from winter storage same thing happened to me the engine stopped dead I was able to rotate the engine back the opposite direction and stopped it again finally when I took the cylinder head off it was filled with birdseed from a mouse but his urine damaged the cylinder wall and it only sat over the winter. BASTARDS!!!
Old 02-23-2020, 07:59 AM
I'am not reading all of this thread, but if you have all the rockers backed off which makes for all the valves being closed, then if you do not have all the plugs out then that's what's keeping the motor from rolling over for you.
