Old 04-07-2020, 02:34 PM
ErikW's Avatar
ErikW ErikW is offline
Default Pistons!
My pistons finally came in from Butler. Heat barrier top coating and anti-friction skirt coating. LS ring pack (1.2mm,1.2mm,3.0mm)With the 94cc Edelbrock heads that SD Performance is doing for me ( 325 cfm with 5/16” stem Manley 2.180” intake valve and a custom 11/32” stem Manley tuliped 1.740” exhaust valve along with small dia. dual valve springs to further reduce weight and T-washers installed) and .056 Cometic (Luhn) head gaskets we'll be right around 9.15:1 - 9.20:1 compression. Rotating assembly went off to the machine shop for balancing today.
ID:	536614   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #62
Old 04-09-2020, 10:09 PM
ErikW's Avatar
Default More Progress
More body panel tweeking and setting up rear wheels and tires for flange to flange measurement so we can calculate the Fab 9" housing dimensions. Thanks to Ray Cox for the awesome wheels! Picking up the rotating assembly in the morning. I'll post shortblock assembly pics over the next couple of days. Stay tuned.
ID:	536868   Click image for larger version
ID:	536869   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #63
Old 04-10-2020, 09:25 AM
Colin70TA Colin70TA is offline
How did the front bumper fit from Stinger? Looking to buy one soon for our track car.
Great job so far, will be an incredible car!
Sent from my SM-A530W using Tapatalk
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, [email protected] 1/8 mile....Sold :-(
  #64
Old 04-10-2020, 06:54 PM
ErikW's Avatar
So far it fits great
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #65
Old 04-11-2020, 05:26 PM
slowbird's Avatar
slowbird slowbird is offline
Awesome thread thanks for sharing
  #66
Old 04-13-2020, 02:24 PM
ErikW's Avatar
Decided to take a break from the car and assemble the short block. Crower billet 4.25 stroke fully couterweighted crankshaft, Oliver 6.800 rods with ARP 2000 bolts and of course Ross Custom turbo pistons. 4.157 bore, 1.2 mm top, 1.2 mm second and 3.0 mm oil ring set. First step was filing ring gaps. .032 top and second for medium boost. Used a BOP one piece rear main seal. The camshaft in the block was just for checking fitment after slamming in the cam bearings. I'm working with Herb from Luhn Performance on a LS firing order hydraulic roller for this motor. The Edelbrock heads should be ready in the next few weeks from SD Performance. So we'll pick up then on engine final assembly.
ID:	537204   Click image for larger version
ID:	537205   Click image for larger version
ID:	537206   Click image for larger version
ID:	537207   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #67
Old 04-13-2020, 02:36 PM
ErikW's Avatar
Started work on the tubular core support. First step was to install the original core support and align fenders to the doors and nose. Then Nick built a quick and dirty support structure to hold the fenders in alignment while removing the factory support. Then he started on tubular supports for the fenders. More to come.
ID:	537209   Click image for larger version
ID:	537210   Click image for larger version
ID:	537211   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #68
Old 04-14-2020, 07:46 AM
BDHABT's Avatar
BDHABT BDHABT is offline
This is such an awesome build!
Now I know why my buddy did not want to 25.5 my car lol.
Thanks for the pics,especially of the core support.We put a Smith frame in our Bird,and did not want to reuse the factory core support;this will give my bud some ideas.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
  #69
Old 04-26-2020, 05:18 PM
wrench's Avatar
wrench wrench is offline
Any updates?
  #70
Old 04-27-2020, 06:29 PM
ErikW's Avatar
Busy week. Nick built the Fab 9" housing from a Vanishing Point Race Cars Kit.(http://www.vp-racecars.com/index.html) It all starts with measuring for housing width, cutting axle tubes to rough length then trimming to final length on the lathe. Then Nick starts on housing fabrication using our homemade jig and a scrap center section. Before the back brace and housing ends are welded on the housing is welded to a beam to help avoid distortion. This whole process took several days as you have to weld and cool many times as you go. We're only allowed 5 pics per post so I'm going to make the next several posts just pics. Also included will be pics of the twin turbo "hot side" mock up.
ID:	538533   Click image for larger version
ID:	538534   Click image for larger version
ID:	538535   Click image for larger version
ID:	538536   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #71
Old 04-27-2020, 06:32 PM
ErikW's Avatar
Rear Housing
ID:	538541   Click image for larger version
ID:	538542   Click image for larger version
ID:	538543   Click image for larger version
ID:	538544   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #72
Old 04-27-2020, 06:38 PM
ErikW's Avatar
Rear housing
ID:	538546   Click image for larger version
ID:	538547   Click image for larger version
ID:	538548   Click image for larger version
ID:	538549   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #73
Old 04-27-2020, 06:44 PM
ErikW's Avatar
Default Progress
Rear housing final
ID:	538555   Click image for larger version
ID:	538556   Click image for larger version
ID:	538557   Click image for larger version
ID:	538558   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #74
Old 04-27-2020, 06:58 PM
ErikW's Avatar
Default Hot side
Hot side fab begins with finding a location for the VS Racing 78/76 T4 turbos. Nick found some awesome turbo mounts from Maven Performance and welded them to our core support "in progress". Then he had to lengthen the driver's side log manifold to protrude through the motor plate like the passenger side log. Then proceeded to run 2.5" stainless to the turbos from there.
ID:	538560   Click image for larger version
ID:	538562   Click image for larger version
ID:	538563   Click image for larger version
ID:	538564   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #75
Old 04-27-2020, 07:02 PM
ErikW's Avatar
Default More Hot Side
More hot side pics
ID:	538566   Click image for larger version
ID:	538567   Click image for larger version
ID:	538568   Click image for larger version
ID:	538569   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #76
Old 04-27-2020, 07:06 PM
ErikW's Avatar
Next will be rear shock x-member and final cage fab, wastegate mounting and plumbing then cold side fabrication. We are goint to use 2 inline tank style air to water intercoolers before the merge into the throttle body. Stay tuned!
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #77
Old 04-27-2020, 10:19 PM
73 TRANSAM 73 TRANSAM is offline
That is an excellent build! My favorite car too! How much horsepower are you projecting to make?
  #78
Old 04-28-2020, 11:21 AM
mysticmissle's Avatar
this thing is super sick great set of skills on the young man
  #79
Old 04-28-2020, 12:15 PM
Could you post up a few more detailed pictures of how you will have the oil drains for the turbos plumbed?
  #80
Old 04-28-2020, 12:24 PM
JC455 JC455 is offline
Amazing work!!! Just awesome!!
John
IG: @crawdaddycustoms
