Old 03-31-2020, 08:26 PM
Willshire's Avatar
Willshire Willshire is offline
Default 1964 Grand Prix Tail Panel Repair
Has anyone repaired the section of tail panel above the tail lights? This tail panel rotted from the trunk seal to the tail light opening. This is like 5 bends in less than 2 inches. I'm just wondering what you guys did. Cat and bonne tail panels dont have the cut outs for the tail lights and i'm noticing this 1 year only is about as rare as frog fur.
Adam
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 03-31-2020, 08:28 PM
Willshire's Avatar
Old 04-01-2020, 08:30 PM
Willshire's Avatar
Sometimes you gotta stand back, grab two pieces of angle iron and a BFH and sort it out. 2 hours, some swearing, and.....you’re done. Lol
Old 04-01-2020, 08:33 PM
MUSLCAH MUSLCAH is offline
Your on your way !
Old 04-01-2020, 08:38 PM
Willshire's Avatar
Thanks. It’s all hidden but, after 5 years of working on it, no point in half assing it. The number of bends kinda concerned me, to the point I was looking for a brake. Measure twice, bend once. Lol
Old 04-01-2020, 10:53 PM
Adam, have you tried Frank's Pontiac Parts in CA or Steve Barrack at Pontiac Heaven in AZ (a member here)? Unless you've spent some time using a sheet metal brake and are comfortable bending compound curves I'd be attempting to find a usable one. One more place to try is Steve Snyder at Colorado Pontiacs (on Facebook).
Dr. Thomas Sowell
Old 04-01-2020, 11:48 PM
I’ve bent many a piece of sheet metal on a piece of angle iron ,attached to my bench. Hammer Time !
Old 04-01-2020, 11:52 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
[email protected]
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-02-2020, 11:30 AM
Willshire's Avatar
Thanks HH. Franks only has a cat tail panel. GP is punched out for the taillights. Dan's Garage in Washington appears to have one but, i think i worked it out. Check out the photo above. First try and i almost got it mint. another hour of messing around and make sure it's as good as i can get it and weld it in.
Thanks again.
Old 04-02-2020, 11:36 AM
Willshire's Avatar
Two 3" x 3/8" angle iron holds it good and tight. to bend over 90 i grabbed a piece of flat bar to sit up above the angle irons. i'm glad it worked out and i saved roughly $400CDN minimum. Small wins. lol
Old 04-08-2020, 05:26 PM
Willshire's Avatar
I’m going to stop doubting my fabrication abilities
Old 04-08-2020, 08:58 PM
Willshire's Avatar
Just a skiff of mud and we’re done!
Old 04-08-2020, 09:12 PM
Float a little lead in there......you can do it !
Old 04-08-2020, 11:42 PM
Willshire's Avatar
Hahaha. Now there is something I’ve never tried! I saw Dan Short do it in Fantom Works once. My temporary home office happens to be right in front of my tv lol. I managed to keep the factory braze weld in the corner. This is one of those builds that if I’d have known what I was getting my self into I’d have bought a car that wasn’t a one year model or at least panels were repopped for it. You can’t beat the experience though.
Old 04-08-2020, 11:55 PM
AZ64GP AZ64GP is offline
Lookin' great, Willshire!
The Following User Says Thank You to AZ64GP For This Useful Post:
Old 04-09-2020, 09:26 AM
My 64 GP is from California.....and haven’t had to fix any rust. I put a new Windsheild in it last year....and to my surprise,there was not one speck of rust in the channel.....and all the clips were mint too.
Old 04-09-2020, 09:33 AM
Willshire's Avatar
I had a good windshield channel. But the rear window was cancerous. I fixed the channel but the clips I ordered were wrong and I didn’t notice until I went to put the trim on and it stuck out an 1/8”. I got some new clips that are correct. I will put the window in when the trunk is complete. Still a ways to go. I have the same problem on the right side as above so another few days on that. I have to repair the structure down the sides of the trunk opening as well. It appears a fair amount of water invaded this trunk over the years.
Old 04-09-2020, 11:32 AM
Yup......Iam thinking my back window ain’t as pristine as the front either....someone was in there before...it appears. But Iam not ripping the scab off that ,just yet.
Old 04-09-2020, 11:46 AM
Willshire's Avatar
The inverse slant didn’t help. Water stands in the corners like a champ. As does the lip under the trunk seal. I think that’s how I got so much cancer in the tail. And 20 years in Ontario winters didn’t help
Old 04-09-2020, 05:17 PM
FYI......when you install the new trunk weather strip....make sure you put down one continuous bead of 3M weather strip adhesive.....may use the whole tube. And a generous bead too.
