Old 04-25-2020, 12:09 PM
Two_70_Converts Two_70_Converts is offline
Default Short drive gone bad
My son decided to get his Mom out of the house for a "fun" short drive. It didn't end well. Tire was sliced open, tie rod bent, shock blew out and of course the obvious. Luckily one of the rare times he wasn't going fast and on a back road. Never had one break at the ball joint before.
The Following User Says Thank You to Two_70_Converts For This Useful Post:
Old 04-25-2020, 12:15 PM
Bluesugar Bluesugar is offline
WOW!!...I have never seen that....I am now going to inspect all my cars in AND around that area!
Old 04-25-2020, 12:34 PM
Brake hose is junk too. From the bottom photo, it doesn't appear as though there was a crack starting. Would need to see the broken metal from a different camera angle.
Old 04-25-2020, 12:54 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
That's strange, never seen it like that. Maybe someone jacked it up there in the past and caused a crack to form? Or an oversize ball joint pressed in that stressed the area?
Old 04-25-2020, 01:18 PM
gtohunter's Avatar
gtohunter gtohunter is offline
Did this not just happen to someone else very recently, pulling out of his garage, or something like that? I remember seeing pics of the same broken control arm...?
Found it...https://forums.maxperformanceinc.com...d.php?t=838970
Jimmy M
68 GTO
The Following 4 Users Say Thank You to gtohunter For This Useful Post:
Old 04-25-2020, 01:58 PM
Simple Man's Avatar
Good thing no one was hurt.
be a simple...kinda man.
Old 04-25-2020, 03:55 PM
Will Will is offline
WOW! That could've been a lot worse. Never seen that happen before.
Had a wheel bearing seize on the freeway in my buddy's Chevy pickup once. That was seriously scary, but at least the wheel stayed pointed in more or less the right direction...
Old 04-25-2020, 04:22 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
2nd case this year so far on this forum.
At least the damage looks minimal considering such a massive failure.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-25-2020, 04:36 PM
gtohunter's Avatar
Happened to my son driving a Monte Carlo, while he was coming down an on ramp to the Interstate at about 50mph ! Not much you can do but hang on hope you don't hit anyone.
Flat bedded home and fixed the damage.
Jimmy M
68 GTO
Old 04-25-2020, 04:42 PM
dataway's Avatar
dataway dataway is offline
I'd be very curious to know if those are reproduction arms .. I notice where the paint is missing I see relatively clean smooth metal underneath .. that would be very rare on original OEM arms.
Something about the shape of the arm in the second picture doesn't look quite OEM to me, too straight on the back edge.
Old 04-25-2020, 04:44 PM
OG68 OG68 is offline
While not common, its not unusual. The Chevelle forums have numerous threads regarding cracked or broken factory lower arms. It usually occurs at low speed or backing out of the driveway.
I had mine inspected and refurbished by Glen Lever.
https://www.lever-family-racing.com/
Old 04-25-2020, 04:52 PM
dataway's Avatar
I witnessed one break on a 1960 Caddy Coupe Deville pulling into a driveway ... like an explosion.
Old 04-25-2020, 04:56 PM
einstein's Avatar
einstein einstein is offline
Makes me wonder if the stress is from the hard stop contact pad being pressured by the tab on the steering arm? If drivers have a habit of turning hard into the limits of the power steering it could possibly cause that stress.
Quite notable though is the lack of rust in the fracture, suggesting the entire fracture is fresh.
Old 04-25-2020, 05:27 PM
A Schab A Schab is offline
I haven’t had a control arm break but I have had the lower ball joint stud pull through the housing on a 79 T/A.
Old 04-25-2020, 06:58 PM
misterp266's Avatar
Wouldn’t the heating of the control arm with a torch when replacing the pressed in ball joint affect the integrity of the control arm at that point? Perhaps it was “overheated” at some point.
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 04-25-2020, 07:13 PM
Fender Paint all good?
Rim good?
Old 04-25-2020, 07:14 PM
SR-71 SR-71 is offline
I wonder why anyone would beat the control with a torch?!?! No reason to do that. Take them to a machine shop and have them pressed out and new ones pressed back in.
Old 04-25-2020, 07:22 PM
misterp266's Avatar
Not everyone does things the right way. Just a thought. . . .
" Darksiders Rule "
Old 04-25-2020, 07:35 PM
necdb3's Avatar
necdb3 necdb3 is offline
A ball joint press is not expensive. A small price to pay to do it right.
Old 04-25-2020, 07:55 PM
Tough lesson to learn by not doing it the right way. Loosing your GTO or life to save a couple bucks is a bad idea.
The Following User Says Thank You to SR-71 For This Useful Post:
